Help, mkl_dcsrgemv
Camuso__Marco
Hi and thanks for the attention! I'm a beginner and i would like to use the mkl library for my thesis. I must use the function mkl_dcsrgemv, but there are always the error: "segmentation error(core dump created)". The code used is the following and i don't see the error. Someone can help me?
code:
#include <stdio.h>
#include "mkl.h"
int main() {
   double *val,*x,*y;
   int *I,*J;
   int k;
   int M;
   char transa='N';
   M=4;
   val=(double *) calloc(M,sizeof(double));
   x=(double *) calloc(M,sizeof(double));
   y=(double *) calloc(M,sizeof(double));
   I=(int *) calloc (M,sizeof(int));
   J=(int *) calloc(M,sizeof(int));
   for(k=0;k<M;++k){
      val=2;
      x=2;
      J=k+1;
      I=k+1;
   I[M+1]=M+1;
  mkl_dcsrgemv(&transa,&M,val,I,J,x,y);
  printf("\n il vettore y: \n");
  for(k=0;k<M;++k){
      printf(" %lf \t %lf \n",val,y);
  return 0;
Gennady_F_Intel
which version of mkl do you use?
I release only all dynamically allocated arrays and linked against mkl 2020. it works
$ ./a.out
 il vettore y:
 2.000000        4.000000
 2.000000        4.000000
 2.000000        4.000000
 2.000000        0.000000
mecej4
Since I is of length M, valid subscripts for I are integers from 0 to M-1, inclusive.
You are attempting to store into I[M+1], which is an invalid memory access.
Gennady_F_Intel
are there any updates? Do you still see the segfault?
