7303 Discussions
How to call lapack routines in Fortran 95 syntax with Xcode
paladinchin
I have problems using lapack in Fortran 95 syntax.
The following program works when Fortran 77 syntax is used:
program main
implicit none
integer, parameter :: n = 2
integer :: ilo, ihi, lda=n, lwork=n, info, ii
real*8 :: a(n,n), ao(n,n), work(n), tau(n)
ilo=1
ihi=n
a(1,1)=1
a(1,2)=2
a(2,1)=4
a(2,2)=5
ao=a
call dgehrd(n, ilo, ihi, a, lda, tau, work, lwork, info)
call dorghr(n, ilo, ihi, a, lda, tau, work, lwork, info)
write(*,*) ao
write(*,*) a
end program
But if I call the following subroutines instead
call gehrd(a, tau ,ilo ,ihi, info)
call orghr(a, tau ,ilo ,ihi ,info)
a warning occurs: symbol(s) not found
Please tell me if I forget any linking steps.
Thank you.
ArturGuzik
Valued Contributor I
did you follow the guidelines from Chapter 7 "Language-specific Usage Options" in MKL User's Manual. You need to build .mod files (explanation why in Section "Compiler-dependent Functions and Fortran 90 Modules" or in Dima's response to one of recent posts on DFTI).
A.
Vladimir_Koldakov__I
New Contributor III
Quoting - paladinchin
Hello, paladinchin,
Did you resolve the problem?
Note that MKL 10.2 versionprovides precompiled (by Intel Fortran Compiler) .mod files.
You need only toinclude 'USE LAPACK95' statement into your code if you use Intel Fortran Compiler and MKL 10.2.
Otherwise .mod files and lapack95 library should be built before.
Vladimir
