How to use DSS to handle a full matrix
Tianyu_D_
Hi there,
I have a program which will randomly generate cases with linear equations to be solved. For most of the cases, the linear equations will be sparse. So I use the DSS to solve them. But when it involves a full matrix problem.The DSS will stack at the dss_reorder and shows forrtl: severe (157): Program Exception -access violation.
Can anyone tell me how to fix this problem in an efficient way? I don't want to add too much codes to check if the matrix is full and add additional routine for the full matrix case.
The attached is my test case for the full matrix problem. Your help will be greatly appreciated.
Thanks!
Tianyu
      PROGRAM Test
      INCLUDE 'mkl_dss.f77'
      INTEGER tIU(:), tJU(:), Idum(:), ITER
      DOUBLE PRECISION tUM(:), tXDIFF(:), tX(:)
      ALLOCATABLE tIU, tJU, tUM, tXDIFF, tX, Idum
      INTEGER nNonZeros,nRow
      INTEGER*8 handle
      INTEGER error
      !OPEN (UNIT=10, FILE='testInfo.dat')
      !READ (10,7004) nNonZeros, nRow
      !CLOSE(10)
      nRow=2
      nNonZeros=4
      ALLOCATE(tIU(nRow+1))
      ALLOCATE(tXDIFF(nRow))
      ALLOCATE(tX(nRow))
      ALLOCATE(tJU(nNonZeros))
      ALLOCATE(tUM(nNonZeros))
      ALLOCATE(Idum(nRow))
      tJU(1)=1
      tJU(2)=2
      tJU(3)=1
      tJU(4)=2
      tIU(1)=1
      tIU(2)=3
      tIU(3)=5
      tUM(1)=0.0751
      tUM(2)=0.0116
      tUM(3)=0.0116
      tUM(4)=-0.0751
      tXDIFF(1)=1
      tXDIFF(2)=0
      !OPEN (UNIT=10, FILE='columns.dat')
      !READ (10,7002) (tJU(II),II=1,nNonZeros)
      !CLOSE(10)
      !OPEN (UNIT=10, FILE='rowIndex.dat')
      !READ (10,7002) (tIU(II),II=1,nRow+1)
      !CLOSE(10)
      !OPEN (UNIT=10, FILE='values.dat')
      !READ (10,7001) (tUM(II),II=1,nNonZeros)
      !CLOSE(10)
      !OPEN (UNIT=10, FILE='loadVector.dat')
      !READ (10,7001) (tXDIFF(II),II=1,nRow)
      !CLOSE(10)
      ITER=1
C---------------------------------------------------------------------------
C Initialize the solver
      error = dss_create(handle, MKL_DSS_DEFAULTS+MKL_DSS_OOC_VARIABLE)
      IF (error .NE. MKL_DSS_SUCCESS ) GOTO 999
C Define the non-zero structure of the matrix
         !    error = dss_define_structure( handle, MKL_DSS_SYMMETRIC,
         !& tIU, nRow, nRow, tJU, nNonZeros )
        error = dss_define_structure( handle, MKL_DSS_NON_SYMMETRIC,
C Reorder the matrix
      IF (ITER.EQ.1) THEN
          error = dss_reorder( handle,  MKL_DSS_GET_ORDER, Idum)
      ELSE
          error = dss_reorder( handle, MKL_DSS_MY_ORDER, Idum)
      ENDIF
C Factor the matrix
      error = dss_factor_real( handle, MKL_DSS_DEFAULTS, tUM)
C Get the solution vector
      error = dss_solve_real( handle, MKL_DSS_DEFAULTS,
     & tXDIFF, 1, tX)
C Deallocate solver storage
      error = dss_delete( handle, MKL_DSS_DEFAULTS )
      OPEN (UNIT=10, FILE='OutValues.dat')
      WRITE (10,7005) (tX(II),II=1,nRow)
      CLOSE(10)
      GOTO 1999
7001  FORMAT(1X,D)
7002  FORMAT(1X,I5)
7003  FORMAT(1X,I,1X,D)
7004  FORMAT(1X,I,1X,I)
7005  FORMAT(1X,D)
999   WRITE(*,*) "Solver returned error code ", error
1999  DEALLOCATE(tIU,tJU,tUM,tXDIFF,tX,Idum)
      END
Gennady_F_Intel
it really failed with version 11.0. Checking with the latest MKL v.11.3.3, I don't see problem - below the output ( I slightly modified the code by adding error status and mkl version )
Intel(R) Math Kernel Library Version 11.3.3 Product Build 20160413 for Intel(R) 64 architecture applications
  (1)...dss_create ==            0
  (2)...dss_define_structure ==            0
  (3)...dss_reoder ==            0
  (4) ...dss_factor_real ==            0
 (5)...dss_solve_real ==            0
 (6)...dss_delete ==            0
the updates file is also attached.
Gennady_F_Intel
Tianyu, thanks for report. What MKL version do you use?
Tianyu_D_
Hi Gennady, I am using MKL 11.0.
Gennady_F_Intel
Tianyu_D_
Thanks Gennady.
Actually, I have extended the full matrix into a sparse matrix by adding one more row and of course one more column as well. In that way, DSS in MKL 11.0 works.
