Intel Dfti equivalent to FFTW "fftw_plan_many_dft"
David_Sall
I am using the Intel Fortran compiler for Windows, Composer XE 2013 SP1.  I am trying to convert my FORTRAN code to use the MKL FFT's, i.e., Dfti library.  I could not find any reference or examples on the FFTW plan, "fftw_plan_many_dft".  Can this be done using the Intel FFT's?  Would it be possible for someone to show me the syntax of how this is done or point me to a reference where it is done?
Thank you very much for your help!
Sincerely,
David
Zhen_Z_Intel
Dear customer,
The MKL provide FFTW3 wrapper API for both C and Fortran, you could refer to this document to use FFTW with MKL. And you could also find example for "dfftw_plan_many_dft" both forward and backwork from $MKLROOT/examples/examples_core_f/fftw3xf/source, hope it would be helpful to you.
Fiona
David_Sall
Hi Fiona!
Thank you very much for your help.  Super easy change to my code!
Sincerely,
David
