Intel MKL (VSL) Correlation 2d error
imanh
I'm trying to do a 2D correlation, I get VSL_CC_ERROR_YSHAPE, or VSL_CC_ERROR_DECIMATION for any combination of possible code! I saw an example here: community.intel.com/t5/Intel-oneAPI-Math-Kernel-Library/2D-convolution-using-VSL-Conv/m-p/1007237#M18992 (even the same exact example throws decimation error for me), and here is my code:
MKL_INT xshape[2] = { 128,128 }, yshape[2] = { 3,3 }, zshape[2] = { xshape[0]+yshape[0]-1,xshape[1]+yshape[1]-1 };
status = vslsCorrNewTask(&task, mode, rank, xshape, yshape, zshape);
if (status != VSL_STATUS_OK) {
printf("ERROR: creation of job failed, exit with %d\n", status);
return;
status = vslsCorrExec(task, x, NULL, y, NULL, z, NULL);
printf("ERROR: job status bad, exit with %d\n", status);
return;
I tried setting vslConvSetStart (set start to [0,0]) -> didnt work
tried setting all the strides to: [1,1] or to [Xshape[1],1] for X \in {x,y,z}
Any combination of the above doesn't work as well.
MRajesh_intel
These are the Visual Studio(V16.9.4) settings (attached image below) which ran the sample and the result (attached image below).
Can you also please specify your visual studio version ?
Rajesh.
MRajesh_intel
The code ran successfully on our end. I used the command: icpc -mkl example.cpp to compile. I am using oneAPI 2021.2 version . Can you please specify your compiler, OS, oneAPI version, so we can reproduce from our end ?
And also here is the sample I tried:
#include <assert.h>
#include <stdio.h>
#include <string.h>
#include "mkl.h"
int main()
    VSLConvTaskPtr task;
    MKL_INT f_shape[] = { 128, 128};
    MKL_INT g_shape[] = { 3, 3 };
    MKL_INT Rmin[] = { 0, 0 };
    MKL_INT Rmax[] = { f_shape[0] + g_shape[0] - 1, f_shape[1] + g_shape[1] - 1 };
    MKL_INT h_shape[] = { Rmax[0], Rmax[1] };
    MKL_INT h_start[] = { 0, 0 };
    MKL_INT f_stride[] = { f_shape[1], 1 };
    MKL_INT g_stride[] = { g_shape[1], 1 };
    MKL_INT h_stride[] = { h_shape[1], 1 };
    double *f = new double[ f_stride[0] * f_shape[0] ];
    double *g = new double[ g_stride[0] * g_shape[0] ];
    double *h = new double[ h_stride[0] * h_shape[0] ];
    for(int i=0; i < f_shape[0]; ++i)
        for(int j=0; j < f_shape[1]; ++j)
            f[ i * f_stride[0] + j ] = 1;
    for(int i=0; i < g_shape[0]; ++i)
        for(int j=0; j < g_shape[1]; ++j)
            g[ i * g_stride[0] + j ] = 1;
    memset( h, 0, sizeof(h[0]) * h_stride[0] * h_shape[0] );
    int status;
    status = vsldConvNewTask( &task, VSL_CONV_MODE_AUTO, 2, f_shape, g_shape, h_shape );
    assert(status == VSL_STATUS_OK);
    status = vslConvSetStart( task, h_start );
    status = vsldConvExec( task, f, f_stride, g, g_stride, h, h_stride );
    status = vslConvDeleteTask(&task);
    for (int i=0; i< h_shape[0]; ++i)
        printf("%3i: ",i);
        for (int j=0; j < h_shape[1]; ++j)
            printf("%4.0f ",h[ i * h_stride[0] + j ]);
        printf("\n");
    return 0;
Rajesh.
imanh
I ran this, and I get all 0s. (the problem is not that it does not run, in this case it does run, but all results are 0)
MRajesh_intel
Rajesh.
imanh
VS2019. My settings are the same EXCEPT for:
User interface: DPC++ API (instead of ILP64)
Use oneMKL: Sequential (but this doesn't matter)
: SO I tried and "ILP64" fixed it. But is this okay? I mean, no warning, no compilation error, just results being wrong when you use the wrong interface?
And I found this on ILP64 vs LP64, but I cant find anything about DPC++ API vs (I)LP64.
Thank you.
MRajesh_intel
Thanks for the confirmation. DPC++ API should be selected if you have DPC++ source code; when working with multiple devices (CPU/GPU) ,using device-specific libraries underneath.
You may try oneMKL DPC++ samples using DPC++ API.
For further reference: https://github.com/oneapi-src/oneMKL
Rajesh.
MRajesh_intel
Please let us know if your issues have been resolved. Can we proceed further to close this thread?
Rajesh.
imanh
yes and thanks for your responses. (I did mark your post as solution I thought that closes it.)
MRajesh_intel
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread. If you require any additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day.
Rajesh.
