7303 Discussions
Pardiso in OOC mode uses same memory as in IC mode
Pan11
I am trying to use pardiso in ooc mode with iparm(60)=2 from fortran.  It generates the ooc files but consumes the same ram as in ic mode iparm(60)=0.  Behavior is the same regardless of the size of the matrix, total or available mem, number or threads, or computer. Tested in centos 7 and 8 using 20.2 relase. Attached is the msglvl=1 output from runs for the same matrix.  Available mem scanned from /proc/meminfo is listed as well.
Thanks for any help.
Pan11
Hi Gennady, thanks for the info.
Also, I have run several large tests and confirmed OOC mode with iparm(24)=1 consumes the memory estimated by iparm(63) mem in phase 22.  I will start another thread for the pardiso_handle_store issues.
Thank you!
Kirill_V_Intel
Hello!
I don't see anything bad about the output you shared, which would explain what you see. One thing maybe: try to leave the swap size set to 0 rather than setting it to something else.
As a quick attempt, can you also try with iparm[23]=1 (so that you don't get the single-level factorization algorithm but rather a two-level one) and let us know the results?
Independent from whether this helps or not, I think we need a reproducer so that we can check what happens on our side.
Best,
Kirill
Pan11
Hi Kirill, thank you for the quick response.
Swap size size does not have an effect.  However, setting iparm(24)=1 (I am using fortran) does reduce the memory consumption in OOC mode.  I will run larger matrices over the next few days and report behavior.
iparm(24)=1 causes segfault whith pardiso_handle_store, which I would also like to use.  Is there a way to use iparm(24)=1 with pardiso_handle_store?
Attached is a sample code and matrix data to reproduce the results.  I had to use a much smaller matrix than the original post due to the upload size limits.
Gennady_F_Intel
regarding the uploading size limit -- we have an official support channel - Intel Online Service Center ( https://supporttickets.intel.com/servicecenter?lang=en-US) and You can open the ticket there against MKL. The uploading size limitation there <= 2Gb.
Pan11
Thank you!
Gennady_F_Intel
The issue is closing and we will no longer respond to this thread.
