I get linking issues of the form
ippsmt.lib(pscopye9as_l9.obj) : error LNK2005: l9_ownsSet_32s_E9 already defined in mkl_core.lib(pscopye9as_l9_20121126.obj)
with Intel C 14.0.1 on Windows x64. I am linking with the libraries
ippcoremt.lib ippdcmt.lib mkl_core.lib ippvmmt.lib mkl_sequential.lib mkl_intel_lp64.lib ippsmt.lib
Any clue to what is wrong?
連結已複製
Now with a readable formatting.
Perhaps the mkl_sequential version conflicts with the ipp threaded version. If you would give us a simple reproducer, we could try it. You could control number of threads used by MKL by setting MKL_NUM_THREADS.
This problem is caused by conflicts of FFT routines in MKL and IPP. The issue has been escalated to the engineering team. We are targeting to fix it in MKL 11.1 update 3 (to be released in May 2014). For now, we suggest users to try one of the two approaches to mitigate the problem:
1. Use only IPP FFT functions and not MKL FFT functions. Link IPP libs before MKL libs. Or,
2. Use only MKL FFT functions and not IPP FFT functions. Link MKL libs before IPP libs.
Thanks for reporting this issue.
