7303 Discussions
MKL: Significantly reduced efficiency in parallel regime
DmitrySkachkov
I am using Intel-oneapi-mkl/2024 to calculate inverse double complex matrix using
getrf/getri programs.
On one core, the calculation time is 0.10 s
However in parallel regime using OpenMP parallelization, the calculation time is significantly increased:
OMP=2 calc.time = 0.16s
OMP=32 calc.time = 10.1s
The size of the complex(8) matrix is 484x484
The program was compiled in hybrid MPI/OpenMP regime and used for one MPI process.
Ruqiu_C_Intel
Thank you for posting your question.
Please provide out a simple reproducer, as well as tell us your test environment(OS, CPU platforms, oneAPI version, etc.), and the steps to reproduce your issue. Also it's good if you test again on the latest oneAPI version(2025.0.1)
DmitrySkachkov
The following code makes inverse of complex matrix using MKL getri program. The version of Intel compiler is 2024.0.2 20231213
Calculation time
OMP_NUM_THREADS=1   22.29s
OMP_NUM_THREADS=2   74.69s
OMP_NUM_THREADS=4   314.15s
The program was compiled with the following options:
ifx -o test.x program.o -qmkl-ilp64=parallel  /opt/shared/intel-oneapi/2024.2.0.634/mkl/2024.2/lib/libmkl_blas95_ilp64.a /opt/shared/intel-oneapi/2024.2.0.634/mkl/2024.2/lib/libmkl_lapack95_ilp64.a -Wl,
--start-group /opt/shared/intel-oneapi/2024.2.0.634/mkl/2024.2/lib/libmkl_intel_ilp64.a /opt/shared/intel-oneapi/2024.2.0.634/mkl/2024.2/lib/libmkl_intel_thread.a /opt/shared/intel-oneapi/2024.2.0.634/mkl/2024.2/lib/libmkl_core.a -Wl,--end-group -liomp5 -lpthread -lm -ldl
  Module MKL95
   include '/opt/shared/intel-oneapi/2024.0.1.46/mkl/2024.0/include/mkl_lapack.fi'
   include '/opt/shared/intel-oneapi/2024.0.1.46/mkl/2024.0/include/mkl_blas.fi'
  end module MKL95
MODULE F95_PRECISION
    INTEGER, PARAMETER :: SP = KIND(1.0E0)
    INTEGER, PARAMETER :: DP = KIND(1.0D0)
END MODULE F95_PRECISION
INCLUDE 'mkl_lapack.f90'
INCLUDE 'mkl_blas.f90'
 module data
   integer, parameter         :: N = 400
   complex(8)                 :: AA(N,N)
   integer                    :: ipvt(N)
 contains
  subroutine set_A
   integer     :: i,j
   real        :: r1(N)
   real        :: r2(N)
   do i=1,N
    call random_number(r1)
    call random_number(r2)
    do j=1,N
     AA(i,j)%re = r1(i)
     AA(i,j)%im = r2(j)
    enddo
   enddo
   do i=1,N
    AA(i,i) = (1.d0,0.1d0)
   enddo
   do i=1,N
    do j=i+1,N
     AA(i,j) = AA(j,i)
    enddo
   enddo
  end subroutine set_A
 end module data
  Program A
   use F95_PRECISION
   use MKL95
   use LAPACK95
   use BLAS95
   use data
   use omp_lib
   integer                    :: info
   real(8)                    :: t0,tf
   call cpu_time(t0)
   do i=1,1000
    call set_A
    call getrf(AA,ipvt,info)
    if(info/=0) print *,' getrf: info=',info
    call getri(AA,ipvt,info)
    if(info/=0) print *,' getri: info=',info
   enddo
   call cpu_time(tf)
   print *,'  t_calc=',tf-t0
  end program A
Aleksandra_K
There is an issue with the way the timing is being measured. When using CPU_TIME, the time returned is the sum of all active threads' CPU times, not the actual wall time.
To estimate the performance or scaling of multithreaded applications, you should use the intrinsic subroutine SYSTEM_CLOCK or the portability function DCLOCK. Both of these routines return the elapsed time from a single clock.
Also, please consider upgrading to oneAPI version 2025.0, as I won't be able to provide advice for earlier versions.
Aleksandra
Aleksandra_K
Did you have a chance to try any of the suggested methods for measuring wall time?
Aleksandra_K
I am closing this issue due to lack of response and will no longer monitor this thread. If you need further assistance, please start a new thread.
