NO SUPPORT FOR RANDOM NUMBER GENERATOR routines ?
WSinc
I am referring to the two routines:
call random_number() and Call random_seed()
Those are not included in any of the categories, and your A to Z index is not available.
Are they supported elsewhere ?
gaston-hillar
Valued Contributor I
Hi Billsincl,
The following link provides the documentation for Random Number Generators in the latest version of Intel Math Kernel Library: https://software.intel.com/en-us/node/521842
Intel MKL VS provides a set of routines implementing commonly used pseudorandom, quasi-random, or non-deterministic random number generators with continuous and discrete distribution.
gaston-hillar
Hi Billsincl,
You can also check the following specific documentation about the Basic Generators: https://software.intel.com/en-us/node/521846
gaston-hillar
Hi Billsincl,
I understood you were talking about Intel Math Kernel Library. However, the routine names make me think that you are probably talking about Fortran. In case your question is related to Fortran, the following link provides documentation for the RANDOM_NUMBER routine: https://software.intel.com/en-us/node/679804
gaston-hillar
BTW, in case your question is related to Fortran, the most appropriate forum is https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows
Ying_H_Intel
Hi billsincl
