Numpy+MKL install fails: Could not locate executable icc
matus_s_
I followed the build instruction on intel's website closely but when get to building numpy I get the following message:
sudo python setup.py config --compiler=intelem build_clib --compiler=intelem build_ext --compiler=intelem install
Running from numpy source directory.
/usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'test_suite'
  warnings.warn(msg)
non-existing path in 'numpy/f2py': 'docs'
non-existing path in 'numpy/f2py': 'f2py.1'
/bin/sh: 1: svnversion: not found
F2PY Version 2
blas_opt_info:
blas_mkl_info:
  FOUND:
    libraries = ['mkl_rt', 'pthread']
    library_dirs = ['/opt/intel/composer_xe_2015/mkl/lib/intel64']
    define_macros = [('SCIPY_MKL_H', None)]
    include_dirs = ['/opt/intel/composer_xe_2015/mkl/include']
  FOUND:
non-existing path in 'numpy/lib': 'benchmarks'
lapack_opt_info:
openblas_lapack_info:
  libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/x86_64-linux-gnu']
  NOT AVAILABLE
lapack_mkl_info:
mkl_info:
  FOUND:
  FOUND:
  FOUND:
/usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution option: 'define_macros'
  warnings.warn(msg)
running config
running build_clib
running build_src
build_src
building py_modules sources
building library "npymath" sources
Could not locate executable ecc
customize Gnu95FCompiler
Found executable /usr/bin/gfortran
customize Gnu95FCompiler using config
C compiler: icc -m64 -fPIC
compile options: '-Inumpy/core/src/private -Inumpy/core/src -Inumpy/core -Inumpy/core/src/npymath -Inumpy/core/src/multiarray -Inumpy/core/src/umath -Inumpy/core/src/npysort -Inumpy/core/include -I/usr/include/python2.7 -c'
icc: _configtest.c
sh: 1: icc: not found
failure.
removing: _configtest.c _configtest.o
  File "setup.py", line 251, in <module>
    setup_package()
  File "setup.py", line 243, in setup_package
    setup(**metadata)
  File "/home/matus/Desktop/numpy-1.9.1/numpy/distutils/core.py", line 169, in setup
    return old_setup(**new_attr)
  File "/usr/lib/python2.7/distutils/core.py", line 151, in setup
    dist.run_commands()
  File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
    self.run_command(cmd)
  File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
    cmd_obj.run()
  File "/home/matus/Desktop/numpy-1.9.1/numpy/distutils/command/build_clib.py", line 63, in run
    self.run_command('build_src')
  File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command
    self.distribution.run_command(command)
    cmd_obj.run()
  File "/home/matus/Desktop/numpy-1.9.1/numpy/distutils/command/build_src.py", line 153, in run
    self.build_sources()
  File "/home/matus/Desktop/numpy-1.9.1/numpy/distutils/command/build_src.py", line 164, in build_sources
    self.build_library_sources(*libname_info)
  File "/home/matus/Desktop/numpy-1.9.1/numpy/distutils/command/build_src.py", line 299, in build_library_sources
    sources = self.generate_sources(sources, (lib_name, build_info))
  File "/home/matus/Desktop/numpy-1.9.1/numpy/distutils/command/build_src.py", line 386, in generate_sources
    source = func(extension, build_dir)
  File "numpy/core/setup.py", line 686, in get_mathlib_info
    raise RuntimeError("Broken toolchain: cannot link a simple C program")
RuntimeError: Broken toolchain: cannot link a simple C program
However icc is available and indeed
$ icc --version
returns
icc (ICC) 15.0.0 20140723
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
as for ecc
$ icecc --version
ICECC 1.0.1
So what is the problem?
I'm on Linux Mint 17
VipinKumar_E_Intel
Did you source the compilervars.sh that is located in <your intel tools installation folder>/bin?
Vipin
Ziyuan
I submitted an issue to numpy. You can temporarily replace the variable old_path with the hard-coded true PATH, or simply add a symlink of icc and ifort in /usr/bin.
sudo potentially changes the PATH. See a related comment on github. So you may want to add paths like /opt/intel/composer_xe_2015.1.133/bin/intel64 to the secure_path in sudoers in this case.
Chaithanya_M_
Even I am facing the similar kind of error.
"Could not locate executable icc" and
"sh: 1: icc: not found"
I have followed all the instructions given on the intel's website. But am not very sure where I went wrong. Please help me.
Ying_H_Intel
Hi Chaithanya,
What the result if you enter the command line?
$ icc --version
or our team has recently released the Intel Distribution for Python (https://software.intel.com/en-us/python-distribution). You are welcome to register and download it. Our binary distribution was built using NumPy 1.9.2 and SciPy 0.15.1 with MKL and intel compiler ICC/ifort.
Ying
