PARDISO crashing 'sometimes' on identical imput (reproducible)
thomas_w_5
Hi. I have a project that worked using vs 2013 and an earlier version
of PARDISO. I just upgraded to vc++ from vs2015 and the current version of mkl
(already to update 2, released a few days ago).
Now, PARDISO crashes - sometimes - using identical input data.
That is, using the same parms and input values, it will sometimes
complete w/o error, sometimes on the 2nd attempt, sometimes on
the 110th and so on. Given enough attempts, it allways crashes using
that data.
i have extracted a small example program that shows the errror.
Basically, its a loop that reads the same data and calls pardiso. i have
tested this on various machines and the crash allways happens - not
allways after the same loopcount, but it does happen.
The resulting binary is missing the
solver DLLs that i use, but those are in the precompiled binaries zip.
To test this, the program needs the path to the data files as
1st parameter. e.g.g: "c:>mkltest d:\temp"
Any ideas what might be causing this and what i can do about this?
WM_THX
-thomas woelfer
Gennady_F_Intel
the expectation time frame is end of August - beginner of September
Mark_H_6
Is there a workaround until the update is out?
Gennady_F_Intel
there is no workaround with that issue.
Gennady_F_Intel
Hello. MKL 11.3.4 has been release a few weeks ago. Could you check how this update works on your side.
schulzey
Has this issue been fixed in MKL 2017?
Gennady_F_Intel
yes. You may try the newest MKL 2017 update 1 ( released Nov 1st ).
