Problems with using MKL sgetrf
taniab
初學者
1,654 檢視
I am compiling a big code base for contour mapping that uses sgetrf and sgetri. The code compiles fine, but I get two error messages as given below, followed by a segmentation fault:
Parameter 1 to routine SGETRF was incorrect
Parameter 1 to routine SGETRI was incorrect
To recreate the error on a smaller test, I have created the attached file test.c.
1) I compiled it using:
g++ -g test.c -lmkl_intel_ilp64 -lmkl_sequential -lmkl_core -lmkl_blacs_intelmpi_ilp64 -lpthread -lm -ldl -lmpi
The original code uses nvcc.
2) MKLROOT is set by setvars.sh to be:
/opt/intel/oneapi/mkl/latest
ls /opt/intel/oneapi/mkl/
2021.2.0/ latest/
Thank you for any help with this.
0 積分
1 解決方案
mecej4
榮譽貢獻者 III
1,621 檢視
If the integer arguments being passed to MKL Lapack and BLAS routines are 32-bit integers, you should not be using the ILP64 libraries. You should use the LP64 libraries, instead. Use the MKL Link Line Advisor to obtain the correct command line.
在原始文章中檢視解決方案
3 回應
mecej4
榮譽貢獻者 III
1,622 檢視
taniab
初學者
1,606 檢視
Thank you so much. Using LP64 libraries fixed the problem.
MRajesh_intel
主席
1,564 檢視
Thanks for the confirmation!
As this issue has been resolved, we will no longer respond to this thread. If you require any additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Have a Good day.
Rajesh
回覆
