Question about parameter setting of PARDISO
Zhanghong_T_
初心者
5,578件の閲覧回数
Dear all,
I use the MKL under WIndows 7 64bit + VS 2012 + MKL 11.0 or 11.2.
I need to solve very large FEM matrix by PARDISO. Currently I set parameters as follows:
  iparm(1) = 1 ! no solver default
  iparm(2) = 3 ! parallel (OpenMP) version of the nested dissection algorithm
  iparm(4) = 0 ! no iterative-direct algorithm
  iparm(5) = 0 ! no user fill-in reducing permutation
  iparm(6) = 0 ! =0 solution on the first n compoments of x
  iparm(8) = 9 ! numbers of iterative refinement steps
  iparm(10) = 13 ! perturbe the pivot elements with 1E-13
  iparm(11) = 1 ! use nonsymmetric permutation and scaling MPS
  iparm(13) = 0 ! maximum weighted matching algorithm is switched-off (default for symmetric). Try iparm(13) = 1 in case of inappropriate accuracy
  iparm(18) = -1 ! Output: number of nonzeros in the factor LU
  iparm(19) = -1 ! Output: Mflops for LU factorization
  iparm(20) = 0 ! Output: Numbers of CG Iterations
  iparm(21) = 1 ! Apply 1x1 and 2x2 Bunch and Kaufman pivoting during the factorization process
  iparm(24) = 1 ! PARDISO uses new two-level factorization algorithm
The peak memory usage would reach to 20 GB (windows task manager->commit size). Is there any better parameter settings to decrease memory usage but don't increase the solution time significant?
Zhanghong Tang
0 件の賞賛
30 返答(返信)
Alexander_K_Intel2
従業員
1,699件の閲覧回数
Just for testing - could you send iparm(60) to 1? I try to check that you correctly read config file. Also, could you set some file name but not only the folder: 'c:\temp\'? Thanks, Alex P.S. Am I correct that you have several process that going to work with one ooc file? It is better to choose different file name for different processes.
Zhanghong_T_
初心者
1,699件の閲覧回数
Dear Alex,
Thank you very much for your kindly reply. I have set file name not just the folder, the file name is
'c:\temp\'//trim(ss2)
where 'ss2' is a character from 'myid'.
In fact, just now I tested by the following command:
mpiexec -wdir "Z:\test" -mapall -hosts 1 n01 2 Z:\fem
where n01 is just the local machine.
and the PARDISO work successfully.
Zhanghong Tang
Alexander_K_Intel2
従業員
1,699件の閲覧回数
Good! And what the name of ooc files stored in correspondent machine in such case?
Zhanghong_T_
初心者
1,699件の閲覧回数
Hi Alex,
The names of these files are:
 Directory of C:\temp
2014/10/02  23:25    <DIR>          .
2014/10/02  23:25    <DIR>          ..
2014/10/02  23:22       196,902,156 0_.ind
2014/10/02  23:22       295,044,736 0_.jal
2014/10/02  23:23     2,147,483,608 0_.lnz
2014/10/02  23:22       147,522,368 0_.lup
2014/10/02  23:22        34,423,440 0_.sin
2014/10/02  23:22        34,423,440 0_.sle
2014/10/02  23:22       202,666,344 0_2.lnz
2014/10/02  23:22                 0 0_3.lnz
2014/10/02  23:22                 0 0_4.lnz
2014/10/02  23:23       195,247,668 1_.ind
2014/10/02  23:22       291,282,696 1_.jal
2014/10/02  23:23       305,741,768 1_.lnz
2014/10/02  23:22       145,641,348 1_.lup
2014/10/02  23:22        34,093,524 1_.sin
2014/10/02  23:22        34,093,524 1_.sle
2014/10/02  23:23                 0 1_2.lnz
2014/10/02  23:23                 0 1_3.lnz
2014/10/02  23:23                 0 1_4.lnz
2014/10/02  23:25                 0 out.txt
              19 File(s)  4,064,566,620 bytes
               2 Dir(s)  54,129,131,520 bytes free
But the problem is that the PARDISO returns error -11 when I run by the following command:
mpiexec -wdir "Z:\test" -mapall -hosts 10 n01 2 n02 2 n03 4 n04 4 n05 4 n06 4 n07 4 n08 4 n09 4 n10 4 Z:\fem
Alexander_K_Intel2
従業員
1,699件の閲覧回数
Small correction, the initial error is -10, the -11 returned by solving step because factorization have not been competed....My feeling is that something incorrect with sile name - they became the same, but i far from my machine to check it. I understand that i am boring, but it is only way to find the issue - could you call pardiso_getenv routine and pring filename that have been returned by pardiso? To make a proof that name a different? Thanks, Alex
Zhanghong_T_
初心者
1,699件の閲覧回数
Dear Alex,
Thank you very much for your kindly reply. I did as you suggested, the screen output is attached.
Zhanghong Tang
Alexander_K_Intel2
従業員
1,699件の閲覧回数
Ok, everything looks correct. Let me some time to play with such configuration (several processes per one node with OOC PARDISO on each). Also, just to reproduce it more correctly, could you print here parameters of iparm(15), iparm(16), iparm(17) and iparm(63) after reordering step?
Alex
Zhanghong_T_
初心者
1,699件の閲覧回数
Dear Alex,
Zhanghong Tang
Zhanghong_T_
初心者
1,699件の閲覧回数
Dear Alex,
Is there any progress the investigate this problem?
BTW: I have set MKL_PARDISO_OOC_KEEP_FILE = 0 but I noticed that the OOC files are not deleted after the solver finished (phase = -1). Is there anything missed?
Finally I wish the PARDISO work like this: if evaluated peak memory is larger than the limit set before (for example, 16 GB), the OOC is enabled and the peak memory should not larger than 16 GB, if evaluated peak memory is smaller than the limit, the IC is enabled. For choosing OOC or IC, I think it can be solved by setting Iparm(60) = 1, the key issue is that after enabled OOC, the peak memory should be limitted to 16 GB, is there any additional settings?
Zhanghong Tang
Zhanghong_T_
初心者
1,699件の閲覧回数
Dear Alex,
Is there any progress to investigate this problem?
Zhanghong Tang
返信
