Strange bad memory of MKL spline function
lucyhua_zhang2003
Dear all,
I am using MKL compilers_and_libraries_2017.4.210 (update 3) and following the developer guide to construct a cubic spline interpolation workflow. However no matter how I configure my inputs the scoeff values from dfdEditPPSpline1D() output stays bad memory allocation. The function return a good status but then crashes in the next function dfdConstruct1D(). I wonder whether I miss something in my configuration or inclusion of files, or whether there is a bug. My source code was copied below with dummy input data.
Tianhua
For compile, I included 34 h files that are enough for my project.
For link I included mkl_core.lib, mkl_core_dll.lib, mkl_intel_ilp64.lib, mkl_intel_ilp64_dll.lib, mkl_sequential.lib and mkl_sequential_dll.lib.
For execution, I included mkl_core.dll, mkl_sequential.dll and mkl_vml_def.dll
Those appear enough.
Dummy source code which has bad memory of scoeff pointer and crashes in the next function.
//setup MKL data structures
#define SPLINE_ORDER DF_PP_CUBIC /* A cubic spline to construct */
int status; /* Status of a Data Fitting operation */
DFTaskPtr task; /* Data Fitting operations are task based */
/* Parameters describing the partition */
MKL_INT nx; /* The size of partition x */
MKL_INT xhint; /* Additional information about the structure of breakpoints */
/* Parameters describing the function */
MKL_INT ny; /* Function dimension */
MKL_INT yhint; /* Additional information about the function */
/* Parameters describing the spline */
MKL_INT s_order; /* Spline order */
MKL_INT s_type; /* Spline type */
MKL_INT ic_type; /* Type of internal conditions */
double* ic; /* Array of internal conditions */
MKL_INT bc_type; /* Type of boundary conditions */
double* bc; /* Array of boundary conditions */
double scoeff[(20 - 1)* SPLINE_ORDER]; /* Array of spline coefficients */
MKL_INT scoeffhint; /* Additional information about the coefficients */
MKL_INT sitehint; /* Additional information about the structure of
interpolation sites */
MKL_INT ndorder, dorder; /* Parameters defining the type of interpolation */
double* datahint; /* Additional information on partition and interpolation sites */
double *r; /* Array of interpolation results */
r = new double[20];
MKL_INT rhint; /* Additional information on the structure of the results */
MKL_INT* cell; /* Array of cell indices */
/* Initialize the partition */
nx = 10;
nsite = 20;
double x[10], y[10];
for (int i = 0; i < 10; i++)
x = i;
y = pow(i, 3);
for (int i = 0; i < 20; i++)
site = i;
for (int i = 0; i < 19 * SPLINE_ORDER; i++)
scoeff = -9999.0;
xhint = DF_NON_UNIFORM_PARTITION; /* The partition is non-uniform. */
/* Initialize the function */
ny = 1; /* The function is scalar. */
yhint = DF_NO_HINT; /* No additional information about the function is provided. */
status = dfdNewTask1D(&task, nx, x, xhint, ny, y, yhint);
if (status == 0)
/* Initialize spline parameters */
s_order = DF_PP_CUBIC; /* Spline is of the fourth order (cubic spline). */
s_type = DF_PP_NATURAL; /* Spline is of the natural cubic spline type. */
/* Define internal conditions for cubic spline construction (none in this example) */
ic_type = DF_NO_IC;
ic = NULL;
/* Use not-a-knot boundary conditions. In this case, the is first and the last
interior breakpoints are inactive, no additional values are provided. */
bc_type = DF_BC_FREE_END; //natural cubic spline
bc = NULL;
scoeffhint = DF_NO_HINT; /* No additional information about the spline. */
status = dfdEditPPSpline1D(task, s_order, s_type, bc_type, 0, ic_type,
0, &scoeff[0], scoeffhint);
//continue only when the internal boundary condition task is successful
if (status == 0)
/* Use a standard method to construct a cubic Bessel spline: */
/* Pi(x) = ci,0 + ci,1(x - xi) + ci,2(x - xi)2 + ci,3(x - xi)3, */
/* The library packs spline coefficients to array scoeff: */
/* scoeff[4*i+0] = ci,0, scoef[4*i+1] = ci,1, */
/* scoeff[4*i+2] = ci,2, scoef[4*i+1] = ci,3, */
/* i=0,...,N-2 */
status = dfdConstruct1D(task, DF_PP_SPLINE, DF_METHOD_STD);
// skip the data construction check, TZ May 2017
sitehint = DF_NON_UNIFORM_PARTITION; /* Partition of sites is non-uniform */
ndorder = 1;
dorder = 1;
datahint = DF_NO_APRIORI_INFO; /* No additional information about breakpoints or
sites is provided. */
rhint = DF_MATRIX_STORAGE_ROWS; /* The library packs interpolation results
in row-major format. */
cell = NULL; /* Cell indices are not required. */
/* Solve interpolation problem using the default method: compute the spline values
at the points site(i), i=0,..., nsite-1 and place the results to array r */
status = dfdInterpolate1D(task, DF_INTERP, DF_METHOD_PP, nsite, site,
sitehint, ndorder, &dorder, datahint, r, rhint, cell);
/* De-allocate Data Fitting task resources */
status = dfDeleteTask(&task);
Tianhua_Z_
It crashes on my side, at the line
No warning, no error message, just termination of execution. The output window after the project terminates was shown in the message to Egor.
'mkl_df_issue.exe' (Win32): Loaded 'D:\NGI\slim_NGI\testMKL\mkl_df_issue\mkl_df_issue\x64\Release\mkl_df_issue.exe'. Symbols loaded.
'mkl_df_issue.exe' (Win32): Loaded 'C:\Windows\System32\ntdll.dll'. Cannot find or open the PDB file.
'mkl_df_issue.exe' (Win32): Loaded 'C:\Windows\System32\kernel32.dll'. Cannot find or open the PDB file.
'mkl_df_issue.exe' (Win32): Loaded 'C:\Windows\System32\KernelBase.dll'. Cannot find or open the PDB file.
'mkl_df_issue.exe' (Win32): Loaded 'D:\NGI\slim_NGI\testMKL\mkl_df_issue\mkl_df_issue\x64\Release\mkl_sequential.dll'. Module was built without symbols....
Tianhua
