The rate function dormtr Intel MKL
yuriisig
I wrote on my page several years ago that the algorithm of completion of Householders method in diagonalization of real symmetric matrices, implemented in Intel MKL package, can be improved significantly. This improvement is introduced now, and this is done cunningly: it is hidden inside the dormql (dormqr) Intel MKL function. When using the dormql (dormqr) function from Lapack package, the time of the computation increases. It corresponds to the use of dlarfb Intel MKL function (old algorithm is used). But even now, taking into account this improvement, the difference between the best diagonalization algorithms for square matrices from Intel MKL package and my diagonalization algorithm for packed matrices reaches 50% when using paralleling. This success is made up ofhttp://software.intel.com/en-us/forums/showthread.php?t=76595&o=d&s=lr and http://software.intel.com/en-us/forums/showthread.php?t=73653&o=d&s=lr. My web page (it is not currently available) and publications, which used my diagonalization, can be downloaded here: http://depositfiles.com/files/fmy2ueaad
P.S.
As these improvements are included in the code of Intel MKL package, it is appropriate to give the information about the necessary changes in LAPACK (CLAPACK) code, which is the basis of Intel MKL package. The below-given code related to the case of storing the initial matrix in the lower triangle in dlarfb.c from CLAPACK 3.2.1 package:
work_dim1 = *ldwork;
work_offset = 1 + work_dim1;
work -= work_offset;
/* Function Body */
if (*m <= 0 || *n <= 0) {
return 0;
if (lsame_(trans, "N")) {
*(unsigned char *)transt = 'T';
} else {
*(unsigned char *)transt = 'N';
if (lsame_(storev, "C")) {
if (lsame_(direct, "F")) {
/* Let V = ( V1 ) (first K rows) */
/* ( V2 ) */
/* where V1 is unit lower triangular. */
if (lsame_(side, "L")) {
/* Form H * C or H' * C where C = ( C1 ) */
/* ( C2 ) */
/* Computing MAX */
i__1 = *k, i__2 = iladlr_(m, k, &v[v_offset], ldv);
lastv = max(i__1,i__2);
lastc = iladlc_(&lastv, n, &c__[c_offset], ldc);
/* W := C' * V = (C1'*V1 + C2'*V2) (stored in WORK) */
/* W := C1' */
i__1 = *k;
for (j = 1; j <= i__1; ++j) {
dcopy_(&lastc, &c__[j + c_dim1], ldc, &work[j * work_dim1
+ 1], &c__1);
/* L10: */
/* W := W * V1 */
dtrmm_("Right", "Lower", "No transpose", "Unit", &lastc, k, &
c_b14, &v[v_offset], ldv, &work[work_offset], ldwork);
if (lastv > *k) {
/* W := W + C2'*V2 */
i__1 = lastv - *k;
dgemm_("Transpose", "No transpose", &lastc, k, &i__1, &
c_b14, &c__[*k + 1 + c_dim1], ldc, &v[*k + 1 +
v_dim1], ldv, &c_b14, &work[work_offset], ldwork);
/* W := W * T' or W * T */
dtrmm_("Right", "Upper", transt, "Non-unit", &lastc, k, &
c_b14, &t[t_offset], ldt, &work[work_offset], ldwork);
/* C := C - V * W' */
if (lastv > *k) {
/* C2 := C2 - V2 * W' */
i__1 = lastv - *k;
dgemm_("No transpose", "Transpose", &i__1, &lastc, k, &
c_b25, &v[*k + 1 + v_dim1], ldv, &work[
work_offset], ldwork, &c_b14, &c__[*k + 1 +
c_dim1], ldc);
/* W := W * V1' */
dtrmm_("Right", "Lower", "Transpose", "Unit", &lastc, k, &
/* C1 := C1 - W' */
i__1 = *k;
i__2 = lastc;
for (i__ = 1; i__ <= i__2; ++i__) {
c__[j + i__ * c_dim1] -= work[i__ + j * work_dim1];
/* L20: */
/* L30: */
} else if (lsame_(side, "R")) {
should be replaced by (I have not edited comments):
work_dim1 = *k;
/* Function Body */
return 0;
} else {
/* ( V2 ) */
/* ( C2 ) */
/* Computing MAX */
/*W := C' * V = (C1'*V1 + C2'*V2) (stored in WORK) */
/* W := C1' */
i__1 = lastc;
i__2 = *k;
work[i__ + j * work_dim1] = c__[i__ + j * c_dim1];
/* W := W * V1 */
dtrmm_("Left", "Lower", "Transpose", "Unit", k, &lastc, &
c_b14, &v[v_offset], ldv, &work[work_offset], k);
if (lastv > *k) {
i__1 = lastv - *k;
dgemm_("Transpose", "No transpose", k, &lastc, &i__1, &
c_b14, &v[*k + 1 + v_dim1], ldv,
&c__[*k + 1 + c_dim1], ldc, &c_b14, &work[work_offset], k);
dtrmm_("Left", "Upper", transt, "Non-unit", k, &lastc, &
c_b14, &t[t_offset], ldt, &work[work_offset], k);
if (lastv > *k) {
/*C2 := C2 - V2 * W' */
i__1 = lastv - *k;
dgemm_("No transpose", "No transpose", &i__1, &lastc, k, &
work_offset], k, &c_b14, &c__[*k + 1 +
c_dim1], ldc);
/* W := W * V1' */
dtrmm_("Left", "Lower", "No transpose", "Unit", k, &lastc, &
/* C1 := C1 - W' */
i__1 = lastc;
#pragma omp parallel for num_threads(4) private(j, i__)
for (i__ = 1; i__ <= i__1; ++i__) {
i__2 = *k;
for (j = 1; j <= i__2; ++j) {
c__[j + i__ * c_dim1] -= work[j + i__ * work_dim1];
/* L20: */
/* L30: */
Make these minor changes, and you will reach the same speed as in dormtr Intel MKL. Now the changes for the remaining cases can be easily introduced. Id like to notice that dlarfb has a lot of applications so the importance of changes submitted by me is quite high.
yuriisig
Quoting yuriisig
...it is appropriate to give the information about the necessary changes in LAPACK (CLAPACK) code...
The article on this topic will appear in November.
yuriisig
Here endurances from this article:
Modification of Diagonalization Algorithms.
To overcome limitations imposed by the 32-bit architecture of the processor, the theory presented in [5] was developed. It required considerable revision of many functions of LAPACK package. These modifications enhanced the performance of diagonalization algorithms in [13] with respect to two parameters: calculation rate (by up to 80%) and demand for computer resources (by a factor of 6). A decrease in the computer resource used allowed calculation of more complex systems. New diagonalization algorithms are also efficient on 64-bit processors.
However, in the LAPACK code, certain nontrivial inaccuracies concerning efficient use of block methods for matrix processing have not yet been eliminated. They considerably reduce the performance of the code obtained by assembling the programs that use the LAPACK package.
Let us consider as example the required modification of the dlarfb function from the LAPACK package (the latest version, 3.2.2). The performance of this function is mainly determined by two calls of the matrix multiplication function dgemm. The choice of this example is governed by the fact that the dlarfb function has numerous applications, not restricted to diagonalization of real symmetric matrices. Let us isolate from the code of the dlarfb function the block responsible for setting the initial symmetric real matrix in the lower triangle of a square matrix, and let us extract from this block the call to the dgemm function responsible for slowing down of the diagonalization program.
CALL DGEMM('Transpose', 'No transpose',
$ LASTC, K, LASTV-K,
$ ONE, C(K+1, 1), LDC, V(K+1, 1), LDV,
$ ONE, WORK, LDWORK)
Here two matrices are multiplied: In the first matrix of dimension LASTC* (LASTV-K), the number of rows is smaller than the number of columns, and in the second matrix of dimension (LASTV-K)* K, the number of columns K is very small (64128 at optimal use of dlarfb function). Because of the small number of columns in the second matrix, the processor cache is used extremely inefficiently. The problem can be solved by passing to multiplication of the transposed matrices (corprespondingly, the multipliers switch places). Then multiplication of the matrices will be set by the following code:
$ K, LASTC, LASTV-K,
$ ONE, V(K+1, 1), LDV, C(K+1, 1), LDC,
$ ONE, WORK, K)
Now the number of columns in the second matrix in the course of calculation of eigenvectors of the initial real symmetric matrix from the eigenvectors of the tridiagonal matrix will be constant and equal to LASTC >> K. In this case, efficient use of the processor cache will be ensured.
Such modification of the code, with proper matrix multiplication strategy, increases the multiplication rate by no less than 35% for the highly optimized code (on old processor, the gain will be still more significant). For the initial dgemm code from the LAPACK package, the difference reaches 45%.
The developers of the LAPACK package and the INTEL Company using the LAPACK package in its work were informed on the possibility of considerable acceleration of the diagonalization procedure.
1. Semenov, S.G. and Sigolaev, Yu.F., Zh. Obshch. Khim., 2006, vol. 76, no. 6, p. 1006.
2. Semenov, S.G. and Sigolaev, Yu.F., Zh. Obshch. Khim., 2006, vol. 76, no. 11, p. 1809.
3. Semenov, S.G. and Sigolaev, Yu.F., Zh. Obshch. Khim., 2007, vol. 77, no. 5, p. 780.
5. Wilkinson, J.H., The Algebraic Eigenvalue Problem, Oxford: Clarendon, 1965.
yuriisig
