7227 Discussions
Unexpected mkl paradiso behaviour in OOC mode (occupying both Ram memory & hardddisk memory)
xian-zhong_guous_cd-
mkl_solver occupies both CPU memory & OOC temp size, it is expected that,it need to occupy less ram memory & occupies more OOC temp size like mumps solver. AUTO is IC whereas OOC is OOC.
Sam
Major version: 11
Minor version: 1
Update version: 0
Product status:  Product
Build: n20130711
On linux 64 bit
Ying_H_Intel
Hi xian-zhong.guous.cd-adapco.com
Thanks for raising the problem. We try to reduce the memory occupy  in Pardiso.  Could you please explain some details about your test scenary or test use the test case?
In the OOC figure, the red line means the Ram memory usage.  What 's the mean of green line, is it Hard Disk memory?  and what the x-axis times means? And could you tell the expected line you hope to see?
As MKL 11.2 release, if possible, could you please try the new version as it include some improvement about the solver.
Ying
What's New in Intel MKL 11.2
Intel MKL PARDISO:
  • Added the ability to store Intel MKL PARDISO handle to the disk for future use at any solver stage
  • Added pivot control support for unsymmetric matrices and out-of-core mode
  • Added diagonal extraction support for unsymmetric matrices and out-of-core mode
  • Added example demonstrating use of Intel MKL PARDISO as iterative solver for non-linear systems
  • Added capability to free memory taken by original matrix after factorization stage if iterative refinement is disabled
  • Improved memory estimation of out-of-core (OOC) portion size for reordering algorithm leading to improved factorization-solve performance in OOC mode
