about 2D FFT
Dawn_L_
      Below is a block of codes for using 2D FFT from MKL:
         MKL_LONG      flen1[2]={nffty,nfftx};
         MKL_LONG      status;
         DFTI_DESCRIPTOR_HANDLE      hand1;
         status=DftiCreateDescriptor(&hand1,DFTI_SINGLE,DFTI_COMPLEX,2,flen1);
         status=DftiCommitDescriptor(hand1);
         status=DftiComputeForward(hand1,tmp);
         tmp is a 2D complex array.
         problems:
         tmp in DftiComputeForward: if tmp is given by tmp[ ][ ] the compiling can go through and the block codes works well. If tmp is given by **tmp and alloc memory to it, the compiling can go through but executing is crushed at DftiComputeForward.
          So, the problem is in/out parameter in DftiComputeForward has to be hard-coding 2D array and cannot be pointer type?
        Any answer is welcomed. Thank you very much.
Dmitry_B_Intel
You are correct, the i/o pointers should point directly to the data, not to the pointers to the rows/columns. See also what FFTW3 documentation says on this.
Dima
Dawn_L_
   Thank you, Dima, for your reply.
   Same block code with different problem as below:
   complex       tmp[nffty][nfftx],swap[nffty][nfftx];
    MKL_LONG      flen1[2];
    flen1[0]=nffty;
    flen1[1]=nfftx;
    MKL_LONG      status;
   Problem: If I define nffty=1024 and nfftx=1024, the executing of program is crushed at  "complex   tmp[nffty][nfftx],swap[nffty][nfftx];"
   Do you think there is size limitation for 2D complex array of tmp and swap?
   Thank you very much in advanced.
Evgueni_P_Intel
Yes, 16 megabytes exceed the typical size of thread stack.
Try allocating the arrays at run time or extend the size of stack using an appropriate compiler switch.
