Why is the parallel version of zheevd slower than the sequential one?
Matthias_R_
I wrote a piece of code to test the speed of the zheevd function(below). Then I use the Intel link advisor to compile it. These are the times I measured:
sequential: 20.15s
TBB: 30.64s
OpenMP: 30.5s
Why is the sequential code faster then either of the parallel version? Is it possible to speedup the zheevd through parallelization?
program STB
    !use mkl_service
    implicit none
    integer(4)      :: num, i
    call test_herm()
contains
    Subroutine  test_herm()
        Implicit None
        integer(4), parameter         :: N =  4000, LDA =  N, LWMAX =  100000
        integer(4)                    :: info, LWORK, LIWORK, LRWORK, i,j
        real(8)                       :: r,c
        integer(4), dimension(LWMAX)  :: IWORK
        real(8), dimension(N)         :: W
        real(8), dimension(LWMAX)     :: RWORK
        complex(16), dimension(LDA, N):: A
        complex(16), dimension(LWMAX) :: WORK
        call mkl_set_num_threads(4)
        call random_seed()
        do i =  1,N
            do j =  1,i-1
                call random_number(r)
                call random_number(c)
                A(i,j) = cmplx(r,c)
                A(j,i) = conjg(A(i,j))
            enddo
        enddo
        do i =  1,N
            A(i,i) = cmplx(r,0)
        enddo
        LWORK  = LWMAX
        LIWORK = LWMAX
        LRWORK = LWMAX
        !call zheevd('N', 'L', N, A, LDA, W, WORK, LWORK, RWORK, &
                     !LRWORK, IWORK, LIWORK, info)
        CALL ZHEEVD( 'N', 'Lower', N, A, LDA, W, WORK, LWORK, RWORK,&
                  LRWORK, IWORK, LIWORK, INFO )
        write (*,*) "Info: ", info
        write (*,*) "Lwork: ", LWORk
        write (*,*) "Liwork: ", LIWORK
        write (*,*) "LRWORK: ", LRWORK
        !write (*,*) W
    End Subroutine test_herm
end program STB
Ying_H_Intel
From the MKL result, it seems the parallel version Nthr (thread number ) =2  is faster and sequential version: 14.54s CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:2, vs. 19.64s CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
what kind of your OS? why your time result is like ./seq.x  20,88s user 0,08s system 99% cpu 20,969 total
​Seem not the real one :
real    0m10.755s            -----> 2 threads
user    0m19.369s
sys     0m0.426s​.  ,
And  it seems the 20.88s (seq)  and 29.97s (2 thread) should be user time in your cases.
thus  29.97ms actually = core 1 + core 2,  the more number of cores,  the bigger of the value.   not the real time (wall times)
​Best Regards,
Ying
Ying_H_Intel
Hi Matthias,
Could you please tell what kind of the CPU and MKL version are you using?
I did checked on  one  Xeon processor:
    : Intel(R) Xeon(R) CPU E5-2699 v3 @ 2.30GHz, 2 processors,  18x2 =36 physical cores, support AVX2
MKL  2017 update 3 .
 Please note:   mkl_set_num_threads(4) in the code.
Test 1:  OpenMP with 4 threads
 ifort zheevd.f90 -mkl
time ./a.out
real    0m6.386s
user    0m21.271s
sys     0m0.445s
Test 2:   Sequential
[yhu5_new@hsw-ep01 ~]$ ifort zheevd.f90 -mkl:sequential -o z_s.out
[yhu5_new@hsw-ep01 ~]$ time ./z_s.out
 Info:            0
 Lwork:       100000
 Liwork:       100000
 LRWORK:       100000
real    0m23.494s
user    0m23.174s
sys     0m0.273s
Test 3:   TBB
[yhu5_new@hsw-ep01 ~]$ ifort zheevd.f90  -Wl,--start-group ${MKLROOT}/lib/intel64/libmkl_intel_lp64.a ${MKLROOT}/lib/intel64/libmkl_tbb_thread.a ${MKLROOT}/lib/intel64/libmkl_core.a -Wl,--end-group -ltbb -lstdc++ -lpthread -lm -ldl -o z_b.out
[yhu5_new@hsw-ep01 ~]$ time ./z_b.out
 Info:            0
 Lwork:       100000
 Liwork:       100000
 LRWORK:       100000
real    0m4.992s
user    1m47.180s
sys     0m9.120s
Test 4:  remove the  mkl_set_num_threads(4) for OpenMP threads.
[[yhu5_new@hsw-ep01 ~]$ ifort zheevd.f90 -mkl -o z_o.out
[yhu5_new@hsw-ep01 ~]$ time ./z_o.out
 Info:            0
 Lwork:       100000
 Liwork:       100000
 LRWORK:       100000
real    0m4.305s
user    1m45.560s
sys     0m1.946s
from the test, the parallel result is  better than sequential.
Ying
I use the below to  verify the linked library:  OpenMP, TBB,  Sequential
[yhu5_new@hsw-ep01 ~]$ ldd z_o.out
        linux-vdso.so.1 =>  (0x00007ffd7970b000)
        libmkl_intel_lp64.so => /opt/intel/compilers_and_libraries_2017.3.191/linux/mkl/lib/intel64_lin/libmkl_intel_lp64.so (0x00007fcf318fa000)
        libmkl_intel_thread.so => /opt/intel/compilers_and_libraries_2017.3.191/linux/mkl/lib/intel64_lin/libmkl_intel_thread.so (0x00007fcf2fe68000)
        libmkl_core.so => /opt/intel/compilers_and_libraries_2017.3.191/linux/mkl/lib/intel64_lin/libmkl_core.so (0x00007fcf2e375000)
        libiomp5.so => /opt/intel/compilers_and_libraries_2017.3.191/linux/compiler/lib/intel64/libiomp5.so (0x00007fcf2dfd2000)
        libm.so.6 => /lib64/libm.so.6 (0x00007fcf2dcaa000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fcf2da8e000)
        libc.so.6 => /lib64/libc.so.6 (0x00007fcf2d6cc000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fcf2d4b6000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007fcf2d2b2000)
        /lib64/ld-linux-x86-64.so.2 (0x00007fcf3233c000)
Matthias_R_
This is the version I have installed:
$ export | grep MKL
MKLROOT=/opt/intel/compilers_and_libraries_2017.3.191/linux/mkl
and this is my cpu
$ cat /proc/cpuinfo
processor       : 0
vendor_id       : GenuineIntel
cpu family      : 6
model           : 61
model name      : Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz
stepping        : 4
microcode       : 0x21
cpu MHz         : 1588.098
cache size      : 3072 KB
physical id     : 0
siblings        : 4
core id         : 0
cpu cores       : 2
apicid          : 0
initial apicid  : 0
fpu             : yes
fpu_exception   : yes
cpuid level     : 20
wp              : yes
flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch epb intel_pt tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap xsaveopt dtherm ida arat pln pts
bugs            :
bogomips        : 4391.13
clflush size    : 64
cache_alignment : 64
address sizes   : 39 bits physical, 48 bits virtual
power management:
processor       : 1
cpu family      : 6
model           : 61
stepping        : 4
microcode       : 0x21
cpu MHz         : 1306.787
physical id     : 0
siblings        : 4
core id         : 0
cpu cores       : 2
apicid          : 1
initial apicid  : 1
fpu             : yes
fpu_exception   : yes
cpuid level     : 20
wp              : yes
bugs            :
bogomips        : 4393.10
clflush size    : 64
power management:
processor       : 2
cpu family      : 6
model           : 61
stepping        : 4
microcode       : 0x21
cpu MHz         : 1130.078
physical id     : 0
siblings        : 4
core id         : 1
cpu cores       : 2
apicid          : 2
initial apicid  : 2
fpu             : yes
fpu_exception   : yes
cpuid level     : 20
wp              : yes
bugs            :
bogomips        : 4393.54
clflush size    : 64
power management:
processor       : 3
cpu family      : 6
model           : 61
stepping        : 4
microcode       : 0x21
cpu MHz         : 1299.938
physical id     : 0
siblings        : 4
core id         : 1
cpu cores       : 2
apicid          : 3
initial apicid  : 3
fpu             : yes
fpu_exception   : yes
cpuid level     : 20
wp              : yes
bugs            :
bogomips        : 4393.44
clflush size    : 64
power management:
Ying_H_Intel
Hi Matthias ,
Thanks for letting us know the CPU type. Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz is 2 physical cores machine, so generally, MKL will use 2 thread automatically.
How do you build the application?
Could you please  remove    call mkl_set_num_threads(4) in the code ,  then try to run  the  below command
>export MKL_VERBOSE=1
>time ./your.out
and copy the result here.
Ying
[yhu5_new@hsw-ep01 ~]$ export MKL_VERBOSE=1
[yhu5_new@hsw-ep01 ~]$ time ./z_o1.out
MKL_VERBOSE Intel(R) MKL 2017.0 Update 2 Product build 20170126 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled processors, Lnx 2.30GHz lp64 intel_thread NMICDev:0
MKL_VERBOSE ZHEEVD(N,L,4000,0x6e1760,4000,0x1ef29960,0x1ef31660,100000,0x1f23ea60,100000,0x1f301f60,100000,0) 22.04s CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1 WDiv:HOST:+0.000
 Info:            0
 Lwork:       100000
 Liwork:       100000
 LRWORK:       100000
real    0m23.803s    -> sequential
user    0m23.396s
sys     0m0.392s
[yhu5_new@hsw-ep01 ~]$ ifort zheevd.f90 -mkl -o z_o1.out
[yhu5_new@hsw-ep01 ~]$ export OMP_NUM_THREADS=2
MKL_VERBOSE ZHEEVD(N,L,4000,0x6e1760,4000,0x1ef29960,0x1ef31660,100000,0x1f23ea60,100000,0x1f301f60,100000,0) 9.17s CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:2 WDiv:HOST:+0.000
 Info:            0
 Lwork:       100000
 Liwork:       100000
 LRWORK:       100000
user    0m19.369s
sys     0m0.426s
Matthias_R_
I did what you suggested and this is the result:
matthias@laptop ~        [8:19:14]
> $ ifort test.f90 -mkl:sequential -o seq.x
matthias@laptop ~        [8:19:20]
> $ ifort test.f90 -mkl -o para.x
matthias@laptop ~        [8:19:29]
> $ time ./para.x
MKL_VERBOSE Intel(R) MKL 2017.0 Update 2 Product build 20170126 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled processors, Lnx 2.20GHz lp64 intel_thread NMICDev:0
MKL_VERBOSE ZHEEVD(N,L,4000,0x6e1520,4000,0xfb05720,0xfb0d420,100000,0xfc93e20,100000,0xfd57320,100000,0) 14.54s CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:2 WDiv:HOST:+0.000
 Info:            0
 Lwork:       100000
 Liwork:       100000
 LRWORK:       100000
./para.x  29,97s user 0,13s system 191% cpu 15,686 total
matthias@laptop ~        [8:19:50]
> $ time ./seq.x
MKL_VERBOSE Intel(R) MKL 2017.0 Update 2 Product build 20170126 for Intel(R) 64 architecture Intel(R) Advanced Vector Extensions 2 (Intel(R) AVX2) enabled processors, Lnx 2.20GHz lp64 sequential
MKL_VERBOSE ZHEEVD(N,L,4000,0x6e0500,4000,0xfb04700,0xfb0c400,100000,0xfc92e00,100000,0xfd56300,100000,0) 19.64s CNR:OFF Dyn:1 FastMM:1 TID:0  NThr:1
 Info:            0
 Lwork:       100000
 Liwork:       100000
 LRWORK:       100000
Do I need to run this on a system with more than 2 physical cores to see a speedup?
TimP
If you force mkl to use more than 1 thread per core, you will not expect full performance. So you will need more than 2 physical cores to exceed 2x parallel speedup.
Matthias_R_
I removed the
line. In my results above you can see that the parallel version uses 2 cores( 195%), which i confirmed in htop. I would expect the parallel version to best roughly twice as fast (or faster at all) for 2 cores. This is not the case. The sequential version ist faster, as you can see above.
Ying_H_Intel
user    0m19.369s
sys     0m0.426s​.  ,
​Best Regards,
Ying
Matthias_R_
You are right. It seems I got confused by Arch's weird time command. If I use the real one I get:
matthias@laptop ~        [18:50:45]
> $ /usr/bin/time -p ./seq.x
 Walltime:    20.5699980000000
 Info:            0
 Lwork:       100000
 Liwork:       100000
 LRWORK:       100000
real 21.11
user 21.02
sys 0.08
matthias@laptop ~        [18:53:22]
> $ /usr/bin/time -p ./para.x
 Walltime:    30.7099960000000
 Info:            0
 Lwork:       100000
 Liwork:       100000
 LRWORK:       100000
real 16.07
user 31.19
sys 0.12
