7234 Discussions
Why the "LAPACKE_spbtrf" always return "-6"?
charlesqhappy
Hi, guys, I use "LAPACKE_spbtrf" to factorize a matrix A, as the following code, but the function always return -6, which indicate that parameter i is an illegeal value(Does it mean that the "lda" is illegal?).
So why it returns -6?
mecej4
The matrix that you chose is not positive definite. The value of ldA is not correct for the 2-D array conventions that you are using. I think that you should spend time reading the MKL documentation. The MKL distribution comes with a number of example codes that are ready to compile, link and run.
Here is C code that worked (I changed the matrix to make it +def.).
#include <stdio.h>
#include <mkl.h>
int main() {
float ab[10] = { 30,31,32,33,34,
                11,12,13,14,0 };
int i,j;
const int n = 5;
int kd = 1;
int lda = n;
int info = LAPACKE_spbtrf(LAPACK_ROW_MAJOR, 'L', n, kd, ab, lda);
printf("info = %d\n",info);
for(j=0; j<=kd; j++){
   for(i=0; i<n; i++)printf("%8.5f ",ab[n*j+i]);
   printf("\n");
return 0;
With such small examples, it is often instructive to use a package such as Matlab so that you can compare solutions, and to construct suitable input matrices. In this case, I increased the values on the principal diagonal, starting with your values, until Matlab told me that the matrix was positive definite.
mecej4
#include <stdio.h>
#include <mkl.h>
int main() {
                11,12,13,14,0 };
int i,j;
const int n = 5;
int kd = 1;
int lda = n;
   printf("\n");
return 0;
charlesqhappy
Hi, Mecej, thanks very much again!
I didn't understand the "lda" well before, that's the main problem. Also a wrong intuition about the format that a positive definite band matrix have.
Now all the program works well! Thanks!
