dfeast_scsrgv and zfeast_hcsrgv Segmentation fault Error
yera__rolando
I am trying solve a generalized eigenvalues problem Ax = λBx by means of dfeast_scsrgv, but, I get SIGSEV error, I test the individual matrices A and B with dfeast_scsrev and all works fine, so I think that is not a problem of data representation.
Attached goes a code example for the problem described.
pd: The hermitian version zfeast_hcsrgv has the same issue. Sorry for the english.
Gennady_F_Intel
which version of mkl did you try?
yera__rolando
2019 update 4, in Linux, I try with both ICC and GCC compilers.
Gennady_F_Intel
the fix of the issue available in MKL 2020.1.
Dan31
I would like to reopen this issue as I am having the same problem.
You can use the very same example as given in this thread's initial post.
My OneAPI version is:
ls -l /opt/intel/oneapi/mkl
total 4
drwxr-xr-x 9 root root 4096 Oct 27 22:15 2025.0
lrwxrwxrwx 1 root root 6 Nov 25 12:29 latest -> 2025.0
Aleksandra_K
Could you please let me know which compiler you are using? This will help me reproduce the issue you're facing.
Thanks and regards,
Aleksandra
Dan31
Thanks Aleksandra for your help and sorry for not replying sooner.
Here is my output:
/opt/intel/oneapi/compiler/latest/bin/icx --version
Intel(R) oneAPI DPC++/C++ Compiler 2025.0.0 (2025.0.0.20241008)
Target: x86_64-unknown-linux-gnu
Thread model: posix
InstalledDir: /opt/intel/oneapi/compiler/2025.0/bin/compiler
Configuration file: /opt/intel/oneapi/compiler/2025.0/bin/compiler/../icx.cfg
Does this help?
Dan31
@Aleksandra_KMy apologies, it seems that dfeast fails only in my program's environment... it runs when i compile it manually.
Will investigate and reply... please do not waste time on this for now.
Daniel
Aleksandra_K
Hi Daniel,
Thank you for the update. I also checked your example manually and it compiled correctly with icpx and the new MKL 2025.0 (there was a small mistake in calling the last function - after m0, the next argument should have been csr_gv_eigenvalues, but it was csr_gv_res, but you probably know about it).
Please let me know if there is something else I can help you in this topic, or confirm that I can close the issue.
Aleksandra
Dan31
OK, I think I got it pin pointed!
I have a task that needs PARDISO call in order to solve linear system of equations first, then I have FEAST call to solve generalized eigenvalue problem.
I need to have them in threads in order to monitor progress.
Segmentation fault occurs in FEAST call if PARDISO call was in thread. If I call PARDISO directly, there is no problem.
Please check the example I provided in a hope that you can reproduce it also.
Problem happens with both gcc and intel compilers (Linux).
Aleksandra_K
Hi Daniel,
Could you share more details on how you ran the code and the error you encountered?  I really want to reproduce it but so far I can't get that error.
Aleksandra
Dan31
Hello Aleksandra,
here are the steps:
- download and extract main.zip
- open terminal in folder where you extracted main.cpp file
- start intel MKL development environment:
source /opt/intel/oneapi/setvars.sh
- compile main.cpp file into executable:
icpx -Wall -g -I/opt/intel/oneapi/mkl/latest/include -c main.cpp -o main.o
icpx -o main main.o -Wl,--start-group /opt/intel/oneapi/compiler/latest/lib/libiomp5.a /opt/intel/oneapi/mkl/latest/lib/libmkl_core.a /opt/intel/oneapi/mkl/latest/lib/libmkl_gnu_thread.a /opt/intel/oneapi/mkl/latest/lib/libmkl_intel_lp64.a -Wl,--no-as-needed -Wl,--end-group -ldl
- run executable:
./main
- Segmentation fault
I did find that using direct compilation:
icpx -I/opt/intel/oneapi/mkl/latest/include -L/opt/intel/oneapi/mkl/latest/lib/intel64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -ldl main.cpp -o main
will yield runnable executable... now I am trying to figure out the difference as I need separate compile and link times as I am using codeblocks IDE... perhaps you see right away what is wrong with my link line?
Aleksandra_K
Please check with this short linking:
icpx main.cpp -o main -I${MKLROOT}/include -L${MKLROOT}/lib/intel64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core
Does it work or do you get errors?
Dan31
Thank you Aleksandra!
It works!
I guess it was libmkl_gnu_thread.a conflict that caused problems in my case... anyway I abandoned linking with static libraries.
Daniel
Aleksandra_K
Hi Daniel,
Great to hear that! Is there something else I can help you with this topic or can I close the issue?
Aleksandra
Dan31
No, that's it. Thank you, you can close the issue.
