dfeast_sygv -4 error, BUT B IS POSITIVE DEFINITE!!!
yera__rolando
Hello all,
I am using the extended eigensolver routines specifically dfeast_sygv function, and I get the following error
==>INFO code =: -4
Intel MKL Extended Eigensolvers Error: Matrix B is not positive definite.
But the matrix B is positive definite!!!
B =
+2.222e-01      +0.000e+00      +1.111e-01      +0.000e+00      +1.111e-01      +0.000e+00      +5.556e-02      +0.000e+00
+0.000e+00      +2.222e-01      +0.000e+00      +1.111e-01      +0.000e+00      +1.111e-01      +0.000e+00      +5.556e-02
+1.111e-01      +0.000e+00      +2.222e-01      +0.000e+00      +5.556e-02      +0.000e+00      +1.111e-01      +0.000e+00
+0.000e+00      +1.111e-01      +0.000e+00      +2.222e-01      +0.000e+00      +5.556e-02      +0.000e+00      +1.111e-01
+1.111e-01      +0.000e+00      +5.556e-02      +0.000e+00      +2.222e-01      +0.000e+00      +1.111e-01      +0.000e+00
+0.000e+00      +1.111e-01      +0.000e+00      +5.556e-02      +0.000e+00      +2.222e-01      +0.000e+00      +1.111e-01
+5.556e-02      +0.000e+00      +1.111e-01      +0.000e+00      +1.111e-01      +0.000e+00      +2.222e-01      +0.000e+00
+0.000e+00      +5.556e-02      +0.000e+00      +1.111e-01      +0.000e+00      +1.111e-01      +0.000e+00      +2.222e-01
using dfeast_syev function give the following eigenvalues.
+5.556e-02
+5.556e-02
+1.667e-01
+1.667e-01
+1.667e-01
+1.667e-01
+5.000e-01
+5.000e-01
all positive.
Here go the matrix A for the general eigenvalues problem
A =
+4.569e+02      +0.000e+00      -3.046e+02      +0.000e+00      +7.616e+01      +0.000e+00      -2.285e+02      +0.000e+00
+0.000e+00      +4.569e+02      +0.000e+00      +7.616e+01      +0.000e+00      -3.046e+02      +0.000e+00      -2.285e+02
-3.046e+02      +0.000e+00      +4.569e+02      +0.000e+00      -2.285e+02      +0.000e+00      +7.616e+01      +0.000e+00
+0.000e+00      +7.616e+01      +0.000e+00      +4.569e+02      +0.000e+00      -2.285e+02      +0.000e+00      -3.046e+02
+7.616e+01      +0.000e+00      -2.285e+02      +0.000e+00      +4.569e+02      +0.000e+00      -3.046e+02      +0.000e+00
+0.000e+00      -3.046e+02      +0.000e+00      -2.285e+02      +0.000e+00      +4.569e+02      +0.000e+00      +7.616e+01
-2.285e+02      +0.000e+00      +7.616e+01      +0.000e+00      -3.046e+02      +0.000e+00      +4.569e+02      +0.000e+00
+0.000e+00      -2.285e+02      +0.000e+00      -3.046e+02      +0.000e+00      +7.616e+01      +0.000e+00      +4.569e+02
can anybody help me here???
I'm getting something wrong???
Im using linux (debian testing).
thanks in advance.
ps. Sorry about the english.
Gennady_F_Intel
Which version of mkl do you try?
yera__rolando
Im using MKL 2019 update 1 version, installed with parallel_studio_xe_2019_update1_cluster_edition package under student licence. Im also using the ICC version that comes in the package.
Gennady_F_Intel
Ok, could you get us the C or F reproducer to check this behavior on our side with the newest versions 2019.3?
yera__rolando
Here go the src file.
Gennady_F_Intel
Thanks for noticing this case. This looks like the issue which will be escalated.
yera__rolando
I switch to the csr version "dfeast_scsrgv"  for the general eigenvalues problem and now I getting SIGSEGV error, the "dfeast_scsrev" works fine with B for the standard eigenvalues problem.
yera__rolando
There was a bug in the code of the previous src file (conformation of the rowIndex data), here go the fixed version, still the behavior of the "dfeast_scsrgv" remain the same.
Gennady_F_Intel
thanks for the update.
Gennady_F_Intel
the matrix checker has been fixed in the latest 2019 u4 version of mkl.
yera__rolando
Thanks you very much!!!!
