mkl_link_tool quiet output?
Matt_Thompson
All,
Perhaps a FAQ, but my search-fu is lacking. My question is: is there a way to get "quiet" output from the MKL Link Tool?  For example:
(1259) $ $MKLROOT/tools/mkl_link_tool -libs --compiler=gnu_f --parallel=no
       Intel(R) Math Kernel Library (Intel(R) MKL) Link Tool v4.4
Output
Linking line:
 -L$(MKLROOT)/lib/intel64 -Wl,--no-as-needed -lmkl_gf_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -ldl
Now, luckily the thing we care about is in stdout and the rest is stderr, but this does look a bit ungainly in, say, log output:
(1260) $ setenv YAYA `$MKLROOT/tools/mkl_link_tool -libs --compiler=gnu_f --parallel=no -libs --noteno`
Output
Linking line:
(1261) $ echo $YAYA
I'd love it if I could pass in --quiet and then nothing would be output to stderr, only the link line. (Oh, and by the way, I am in a tcsh environment (for legacy reasons) so '2>/dev/null' is not an option thanks to csh being csh.  But I could workaround that. I just would like a --quiet so I can be lazy!)
Ying_H_Intel
Hi Matt,
Thank you for asking. We will see if it is convenient to give a quiet result.
Ying
Ying_H_Intel
Hi Matt,
I'm glad to notify you that MKL 2018 update 1 release recently, the problem in command should be fix in the version.  You are welcomed to try the version and let us know if any problem.  You can get it from https://registrationcenter.intel.com/en/products/ .
Ying
