7298 Discussions
x86GPUs occurs problem that douple precision is not supported
qingfeng
when I use MKL on x86 GPU, compilation can pass but the double precision is not supported when executing. So can I solve it ?
VidyalathaB_Intel
Thanks for providing the details.
The following GPUs are the only supported devices for using intel oneMKL as of now.
Intel® HD Graphics
Intel® UHD Graphics for 9th, 10th, and 11th Gen Intel® Processors
Intel® Iris® Plus Graphics
Intel® Iris® Xe Graphics
Intel® Iris® Xe Max Graphics
Intel® Iris® Graphics
Intel® Iris® Pro Graphics
Please refer to the below link for more details.
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/oneapi-math-kernel-library-system-requirements.html
>> Device: Vivante OpenCL Device CC8400.6305.0000... but the double precision is not supported when executing
We suggest you try the supported devices.
Please do let us know if you face any issues with the supported devices (Intel GPU's) if there is nothing else please confirm whether we can close this thread from our end.
Vidya.
qingfeng
I went to check the calling interface of the function and defined the data type of the input parameter as double, but my GPU is x86
VidyalathaB_Intel
>>my GPU is x86
Could you please let us know which GPU you are using for running your program along with your OS environment details and MKL version?
It would be a great help if you provide us with a sample reproducer so that we can try it from our end.
Please refer to the below link for more details regarding the system requirements of Intel oneMKL
Vidya.
VidyalathaB_Intel
Reminder:
As we have not heard back from you, do you have any updates? Please provide us with a sample reproducer and the above-mentioned details so that we can work on it from our end.
Vidya.
qingfeng
Hi  Vidya
I looked at the source code and there is a check for double determinations.
Another error occurs when I comment out the check item. It is " terminate called after throwing an instance of 'cl::sycl::memory_allocation_error'"
VidyalathaB_Intel
Thanks for providing the details of your code.
We tried it from our end and were able to run the block_cholesky_decomposition successfully.
Below are the environment details on which I have tried.
OS: Ubuntu 18.04
MKL: 2021.4.0
Device: Intel(R) UHD Graphics 630 [0x3e98]
As per the system requirements, Gen9 or higher versions of GPU are supported.
https://www.intel.com/content/www/us/en/developer/articles/guide/intel-graphics-developers-guides.html
Could you please let us know which GPU you are using for running your program and also MKL version?
Vidya.
qingfeng
hi Vidya
Thanks for your reply.
OS: 18.04.1-Ubuntu
MKL: 2021.4.0
qingfeng.
VidyalathaB_Intel
Intel® HD Graphics
Vidya.
VidyalathaB_Intel
Thanks for accepting our solution.
As the issue is resolved we are closing this thread. Please post a new question if you need any additional information from Intel as this thread will no longer be monitored.
Have a Nice Day!
Vidya.
