Hi -
I'm trying to build tpp using the intel compiler. The bin directory containing it is on my $PATH. There is a CXX environment variable that contains icpc and a CC environment variable that contains icc, but when I run make it uses gcc. I am doing the build on CentOS 7.
Is there something I'm not doing that will make it use the intel compiler?
Craig
Hi, Craig.
You can configure compiler by setting parameter to make compiler={icc, gcc, clang}
Also, please make sure that you set up Intel Compiler env before your experiment.
Hi Craig,
In addition, you may find interesting the topic on github about compiler=$(CXX).
Alex
