2477 Discussions
Building TBB with mingw : enable-runtime-pseudo-reloc-v2 error
Nicolas_Pays
Hi All,
I'm trying to use tbb with code blocks (10.05, with gcc 4.4 and gmake 3.81 coming with the installer).
So I'm first trying to build the .a and .dll for tbb and tbb_malloc (i've always worked with the visual binary versions until now)
When i run "mingw32-make compiler=gcc arch=ia32 runtime=mingw tbb", it creates the object files correctly in the build folder, but fails at the link step with the following message:
g++ -o tbb_debug.dll concurrent_hash_map.o concurrent_queue.o concurrent_vecto
r.o dynamic_link.o itt_notify.o cache_aligned_allocator.o pipeline.o queuing_mut
ex.o queuing_rw_mutex.o reader_writer_lock.o spin_rw_mutex.o spin_mutex.o critic
al_section.o task.o tbb_misc.o mutex.o recursive_mutex.o condition_variable.o tb
b_thread.o concurrent_monitor.o private_server.o rml_tbb.o task_group_context.o
governor.o market.o arena.o scheduler.o observer_proxy.o tbb_main.o concurrent_v
ector_v2.o concurrent_queue_v2.o spin_rw_mutex_v2.o task_v2.o -lpsapi -shared
-Wl,--enable-runtime-pseudo-reloc-v2 -m32 -Wl,--version-script,tbb.def
c:/program files (x86)/codeblocks/mingw/bin/../lib/gcc/mingw32/4.4.1/../../../..
/mingw32/bin/ld.exe: unrecognized option '--enable-runtime-pseudo-reloc-v2'
/mingw32/bin/ld.exe: use the --help option for usage information
collect2: ld returned 1 exit status
mingw32-make[1]: *** [tbb_debug.dll] Error 1
mingw32-make[1]: Leaving directory `[..]/tbb30_035/build/windows_ia32_gcc_mingw_debug'
mingw32-make: *** [tbb] Error 2
What did I do wrong ?
Vladimir_P_1234567890
Hi Nicolas,
This option is used in binutils v2.20. if you use older version of binutils/ld (e.g. 2.17) you can try just to delete it.
--Vladimir
Actually the problem caused by absence ofenable-runtime-pseudo-reloc-v2 option was fixed in binutils2.20.51 so I suppose that we will also remove this option from our makefiles.
--Vladimir
Nicolas_Pays
thank you i'm gonna try that.
I forgot to mention i used the latest commecial aligned TBB 3.0 sources.
Nicolas.
right, the option was added to the latest released versionin order to support mingw gcc 4.5.
--Vladimir
