Hi All,
I'm trying to use tbb with code blocks (10.05, with gcc 4.4 and gmake 3.81 coming with the installer).
So I'm first trying to build the .a and .dll for tbb and tbb_malloc (i've always worked with the visual binary versions until now)
When i run "mingw32-make compiler=gcc arch=ia32 runtime=mingw tbb", it creates the object files correctly in the build folder, but fails at the link step with the following message:
g++ -o tbb_debug.dll concurrent_hash_map.o concurrent_queue.o concurrent_vecto
r.o dynamic_link.o itt_notify.o cache_aligned_allocator.o pipeline.o queuing_mut
ex.o queuing_rw_mutex.o reader_writer_lock.o spin_rw_mutex.o spin_mutex.o critic
al_section.o task.o tbb_misc.o mutex.o recursive_mutex.o condition_variable.o tb
b_thread.o concurrent_monitor.o private_server.o rml_tbb.o task_group_context.o
governor.o market.o arena.o scheduler.o observer_proxy.o tbb_main.o concurrent_v
ector_v2.o concurrent_queue_v2.o spin_rw_mutex_v2.o task_v2.o -lpsapi -shared
-Wl,--enable-runtime-pseudo-reloc-v2 -m32 -Wl,--version-script,tbb.def
c:/program files (x86)/codeblocks/mingw/bin/../lib/gcc/mingw32/4.4.1/../../../..
/mingw32/bin/ld.exe: unrecognized option '--enable-runtime-pseudo-reloc-v2'
/mingw32/bin/ld.exe: use the --help option for usage information
collect2: ld returned 1 exit status
mingw32-make[1]: *** [tbb_debug.dll] Error 1
mingw32-make[1]: Leaving directory `[..]/tbb30_035/build/windows_ia32_gcc_mingw_debug'
mingw32-make: *** [tbb] Error 2
What did I do wrong ?
