ERROR MSVCP100.dll is missing
nilsm
Hello everyone,
I had use the TBB to optimize a fractal-program and it woks very well on my PC. I used Microsoft Visual Studio on Windows 7. But when I try to start the program on a other PC I became a runtime-error: MSVCP100.dll is missing. I have find out that MSVCP100.dll is a Library that allows to work onassembler-level and that thector of the scheduler needs the dll, but I could find a answer to solve that problem.
Tux__the_Linux_Pengu
Quoting nilsm
Hello everyone,
Hello!
I think you have to install the VC++ redistributable package(on the computer with the error), according to here:
http://social.msdn.microsoft.com/Forums/zh-en/vcgeneral/thread/e2732f7a-9ce7-4f82-a422-b69ea88f9e8f
Vladimir_P_1234567890
Hi nilsm,
which version os visual studio do you use? you need to take appropriate dlls for that visual studio.
for example if you use visual studio 2008 you need to take tbb binaries from vc9 folder. if you use composer or compiler 11.1 you can select "use TBB" flag.
--Vladimir
Hi nilsm,
--Vladimir
Isn't msvcp100.dll something to do with Microsoft? (ms=Microsoft)
Quoting nilsm
Hello everyone,
You could also build statically.
http://social.msdn.microsoft.com/Forums/en-US/vcprerelease/thread/0ce7f89d-dbca-44c7-82b3-b49958ce89d0
AFAIK this is C++ runtime for visual studio 2010. open source tbb binaries depends on runtime. So you just need to take tbb.dll version from the appropriate bin\\vc* folder.
--Vladimir
to build tbb with static runtime you can pass 'runtime=vc_mt' parameter to the make, e.g.
[bash]gmake runtime=vc_mt[/bash]
--Vladimir
--Vladimir
However, if tbb depends on c++ runtimes, won't you need the c++ runtime and the tbb.dll? Sorry if I'm getting annoying!
I'm not sure I understood the question. Could you pls re-phrase it?
as example
bin\ia32\vc9\tbb.dll depends on
msvcr90.dll- runtime
msvcp90.dll C++
kernel32.dll
bin\ia32\vc10\tbb.dll depends on
msvcr100.dll- runtime
msvcp100.dll C++
kernel32.dll
so in case you have VS 2008 installed you need to use
bin\ia32\vc9\tbb.dll which should automatically take libraries installed on your machine. and if you haveVS 2010 installed you need to use bin\ia32\vc10\tbb.dll
--Vladimir
What I mean is, if you don't have any version of vc++ or tbb on the machine with the error, won't you need the tbb dll and the c++ runtime, or just the vc++ runtime?
I'm guessing that thisthread is resolved.
