2452 Discussions
Error with the executable linked both with TBB and Qt
Hamlet_A_
Hi guys,
Here's the simple code I'm compiling:
// simple.cpp
int main() { return 0; }
And here are the compiler options:
g++ -O2 -I$(INCLUDES) -DNDEBUG  simple.cpp -L$(QT_PATH) -lQtCore -L$(TBB_PATH) -ltbb -o simple
Then, once I run the ./simple, I get the following:
terminate called after throwing an instance of 'std::runtime_error'   what():  TBB failed to destroy task scheduler TLS: Invalid argument
It's interesting that, if I change the order I link to these two libraries, I get no error. I mean:
g++ -O2 -I$(INCLUDES) -DNDEBUG  simple.cpp -L$(TBB_PATH) -ltbb  -L$(QT_PATH) -lQtCore  -o simple
In this case, everything works just fine.
I'm using g++ (GCC) 4.5.2, Qt 4.7.2, TBB 4.1 2013.03.14, RedHat Enterprise Linux 4.0 U8, x86_64, Linux 2.6.9-89
Has anyone else experienced a similar thing or it's just me? Any comments are appreciated.
Thanks in advance,
Hamlet
