Flow Graph - Suggestion
ronag89
I've noticed what seems to me a suboptimal semantics of the flow graph api.
In particular when a node switches set (push/pull) the switch is possibly unnecessarily complicated.
Given two nodes S (s) (sender) and R (r) (receiver).
All nodes start out in the push set.
S tries to push to R and fails. S then removes R from it's successors and adds itself to Rs predecessors.
// s
args : {v}
if (!r.try_put(v))
     succesors.remove(r);
     r.register_predecessor(*this);
// r
args : {s}
predecessors.add(s);
The inherent problem here is that between "try_put" failing and "register_predecessor"  things can happen. So we need to add some stuff.
// s
args : {v}
if (!r.try_put(v))
     if(r.register_predecessor(*this))
     else
         break;
// r
args : {s}
if (can_process_new_items && s.try_get(v))
      process(v);
      return false;
return true;
It think this extra complexity can be avoided by changing the API by allowing nodes to take ownership of edges directly in the try_put/try_get methods.
e.g.
// s
args : {v}
if (!r.try_put(v, this))
// r
args : {s}
if (!can_process_item)
    return false;
Soo, the sender/receiver interface would be change to something like:
template<typename T>
struct receiver
      using input_type = T;
      using predecessor_type = sender<input_type>;
      bool try_put(input_value& v, predecessor* s = nullptr);
struct sender
      using output_type = T;
      using successor_type = receiver<output_type>;
      bool try_get(output_type& v, successor_type r = nullptr);
      void register_sucessor(sucessor_type& r); // only used by make_edge
Any thoughts? Is this a good idea? Am I missing something?
ronag89
Here is a more complete example of how it could look. Probably buggy and a lot slower than the real tbb implementation but it does show the basic idea.
https://github.com/ronag/tasket/blob/master/tasket.h
