2485 Discussions
multifunction_node try_put to output_port fails?
ronag89
What happens when a try_put to an output_port fails? Is the value lost?
RafSchietekat
Valued Contributor III
If you don't do something else with it, that would seem to be the logical conclusion.
Trying again might cause livelock, trying again with a delay would cause undersubscription and maybe still livelock.
You could buffer the value inside the Body and try again during the next execution, or use an external buffer_node.
If you externalise you have the possibility to introduce flow control.
Disclaimer:​I think that the documentation needs some TLC, so that will be my excuse if I'm mistaken. :-)
ronag89
So connecting a multifunction_node to a rejecting node is probably a bad idea.
I would like to achieve something like this:
overwrite_node -> function_node with single in multiple out (i.e. multifunction_node) -> other node -> function_node
Where if the last function_node (or some other) rejects a message it will cause the overwrite_node to drop messages but any message that has passed the overwrite_node must be completed (i.e. the message can become active with a try_get).
Any ideas?
This seems to work if it wasn't for the need of the multifunction_node.
ronag89
Now that I think about it. multifunction_nodes are very dangerous.
If I connect a multifunction_node to a function_node with limited concurrency messages can simply disappear. Which can be very surprising to developers...
Either multifunction_node should be removed from the API or the documentation should very explicitly warn about this.
Michael_S_
You'd better say with disabled internal buffer (aka rejecting policy). A function_node with queuing policy and serial concurrency will handle all incoming messages.
Please, do not recommend removing multifunction_node. It is extremely useful. Only this node can produce any number (0 or >1) of outgoing messages per one incoming message.
