How to install oneTBB per object
jiboxiake
Working on a server machine and it has oneTBB installed already. However I want to modify some classes slightly for my own project's need. So I feel the best way is to install it as a library for my project. Is there a way to add that? Thanks.
NoorjahanSk_Intel
You can install the standalone version of oneTBB library.
Please refer to the below link to get the oneTBB standalone library.
https://www.intel.com/content/www/us/en/developer/articles/tool/oneapi-standalone-components.html
Hope this helps to resolve your issue. If not, could you please elaborate more about your issue so that we can investigate from our end?
Thanks & Regards,
Noorjahan.
jiboxiake
Hello! Thank you so much! I actually later resolved that I may not necessarily need to reimplement something. But I do have some question about accessors in concurrent hash map. I'm trying to understand how regular accessor allows updates in the map but const_accessor does not. From online examples, I found out the standard way of using this map is through creating an appropriate accessor, and call the lookup with the key and accessor. I find out an insert will create an accessor, insert with the key and accessor, and assign accessor's second to the value we want to insert. So can I say accessors are set to copy the values of the key not the pointers to the values? Thanks.
NoorjahanSk_Intel
Yes, you are right.
Accessors of Concurrent_hash_map copy the values of the key. If they use pointers then the element can be modified concurrently resulting in a data race.
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
jiboxiake
Hello, sorry I forgot to respond. Everything works well. Thanks!
NoorjahanSk_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Noorjahan.
