From the release notes of TBB 4.4 Update 6 I can see the following:
"For 64-bit platforms, quadrupled the worst-case limit on the amount
of memory the Intel TBB allocator can handle."
What was the memory limit in the earlier versions of TBB?
Hi Ritwid and Maxim,
The same code file within the source code included in tbb-4.4.5 release includes the following comment:
struct BackRefMaster { /* A slab block can hold up to ~2K back pointers to slab blocks or large objects, * so it can address at least 32MB. The array of 64KB holds 8K pointers * to such blocks, addressing ~256 GB. */
So, addressing has been quadrupled and increased from ~256 GB to ~1TB.
Hello
According to comment in the file ( https://github.com/01org/tbb/blob/tbb_2017/src/tbbmalloc/backref.cpp#L63 ), the minimal guaranteed is a ~1TB in a current version for 64bit systems
Hi Ritwik and Maxim,
The same code file within the source code included in tbb-4.4.6 release includes the same comment than Maksim mentions for the newest release.
Thanks!
