Mixing TBB loops and PPL data structures
Ravi__Jagannadhan
Hi all, is it possible to do mix, say, a TBB::parallel_for loop and the concurrent_* data structures from Microsoft's PPL?
Mark_L_Intel
In theory should be possible. In fact, you can find that PPL took inspiration from TBB, e.g., https://stackoverflow.com/questions/7515097/what-are-the-differences-between-intel-tbb-and-microsoft-ppl
But it is not recommended to mix different threading models in the same application due to possible oversubscription issues (you would activate two different treading pools).
Mark_L_Intel
Due to no response from customer, the Intel support for this ticket is closed.
