I am working on an image processing application which is built with tbb::flow_graph.
The input comes from a video file or a camera.
Each image processing node is wrapped in a multifunction_node (I need the multifunction_node's ability to selectively stop propagating graph messages).
Currently I am using graph.wait_for_all() after feeding each input frame into the root node, but I would like to be able to take advantage of pipeline parallelism.
I.e. if node A is connected to node B, I would like to let node A start working on its next input after it is done producing its output for B, instead of waiting for B to finish.
Could you please provide cues for how to do this efficiently and idiomatically?
I am new to TBB and I feel that I might be missing something obvious.
I apologize for the delayed response on your question.
I recommend using the async_node class. You can set up the async_node to process node A's input while node B is still waiting. See https://www.threadingbuildingblocks.org/docs/help/reference/flow_graph/async_node_cls.html for details.
I am closing this thread for Intel support. Any future replies will be considered community only.
