2455 Discussions
Potential leak in class internal::continue_input
Laurent_D_
Hello everybody,
I am hunting memory leaks in our application that use tbb. I am using a tool and during my debugging I see something that look like a memory leak in Intel TBB.
In the class internal::continue_input (_flow_graph_node_impl.h), "my_body" is allocated in the constructor. But it's not destroyed.
Can someone else confirm this ? Did I miss something ?
Laurent Desmecht
Christophe_H_Intel
Hello, Laurent,
Thank you very much for the report; good catch.  The fix should appear in the next update.
Chris
