Some codes that used to run with TBB 2.2 do not seem to work with TBB 3.0. I have gone through release notes and changes and it does not seem to indicate back compatibility issues. I use Xeon/CentOS 5.5 with intel64/cc4.1.0_libc2.4_kernel2.6.16.21
In general, using tbb/tbb.h does not seem to work, but a work around was to use all the relavant header fiiles.
More specifically the problems are with:
1. concurrent_bounded_queue
2. parallel_for_lambda
3. parallel_invoke
I am giving a sample code that works with TBB 2.2 and corresponding compilation errors with TBB 3.0
3. parallel_invoke
[bash]#include#include #define N 5 using namespace std; using namespace tbb; typedef concurrent_bounded_queue CQ; int main() { CQ cq; CQ::iterator it_cq; for ( int i=0; i Error: [bash]concurrent_bounded_queue.cpp(9): error: concurrent_bounded_queue is not a template typedef concurrent_bounded_queueCQ; ^ concurrent_bounded_queue.cpp(14): error: name followed by "::" must be a class or namespace name CQ::iterator it_cq; ^ concurrent_bounded_queue.cpp(14): error: expected a ";" CQ::iterator it_cq; ^ concurrent_bounded_queue.cpp(21): error: identifier "it_cq" is undefined for ( it_cq = cq.unsafe_begin(); it_cq != cq.unsafe_end(); it_cq++ ) { ^ concurrent_bounded_queue.cpp(36): warning #592: variable "x" is used before its value is set cq.try_pop( x ); ^ compilation aborted for concurrent_bounded_queue.cpp (code 2) [/bash]
2. parallel_for with lambda (icc, -std=c++0x)
[bash]#include#include #include #define N 20 using namespace std; using namespace tbb; void func( long *ptr_x ) { *ptr_x = -(*ptr_x); } void par_func(long a[]) { parallel_for( long(0), long(N/2), long(2), [=](long i) {func( &a );} ); } int main() { task_scheduler_init init(-1); long a ; for ( long i=0; i = i; } par_func(a); for ( long i=0; i ); } return 0; } [/bash]
Error:[bash]parallel_for_lambda3.cpp(17): error: no instance of overloaded function "parallel_for" matches the argument list argument types are: (long, long, long, __lambda1) parallel_for( long(0), long(N/2), long(2), [=](long i) {func( &a );} ); ^ compilation aborted for parallel_for_lambda3.cpp (code 2) [/bash]
3. parallel_invoke[bash]#include#include #include #define N 10 using namespace std; using namespace tbb; class FObject { public: void operator ()() { cout << "Hello World!" << endl; } }; void Say() { cout << "Yeah!" << endl; } int main() { task_scheduler_init init(4); FObject f; parallel_invoke(f, Say); return 0; } [/bash]
Error:[bash]parallel_invoke.cpp(3): catastrophic error: could not open source file "tbb/parallel_invoke.h" #include^ compilation aborted for parallel_invoke.cpp (code 4) [/bash]
Interestingly, the header files that show the error "could not open source file" were in expected directories with read permission and seem fine.
What could be causing the above errors?
TIA,
-Sinedie
The new error is different - as far as I can tell, the linker can not find a symbol that exists in TBB 3.0 but not in earlier versions. So it seems an old version of TBB is used, which confirms that the environment is screwed up.
I think the issue might be because the OS distribution mighthave installed an old version of TBB into system directories, like /usr/include and /usr/lib, and the tools search these directories even before any paths specified via INCLUDE, LIB, etc. One way to check where TBB binaries are taken from is to create a simplest TBB test that only uses e.g. task_scheduler_init which (in theory) should build without a problem, and then check dependencies with ldd; it should tell which libtbb.so is taken to resolve the dependency.
We do not test on CentOS, but I checked your CQ and parallel_for examples on Windows with VS2010 and icl 12.0, and on Linux with a various gcc including 4.4.4, and they work fine (except that gcc does not support lambdas). So I think there is something wrong with either your compiler or its settings. Check e.g. what does INCLUDES env. var. contain? It may point to a place where an older version of TBB is installed.
Thanks Andrey for the response.
I compile using icc (ver. icc (ICC) 11.1 20090630). gcc is ver. 4.1.2 20080704 (Red Hat 4.1.2-48)
The examples given still run on the same system with TBB 2.2. when I source tbbvars.sh from the relavant directory.
As of INCLUDE:
By default TBB 3.0 is loaded. The env variables are:
I checked all the env variables with tbb using 'grep -i'. I found that CPATH, LD_LIBRARY_PATH and LIBRARY_PATH have the relavant directories begin with proper TBB (2.2) directories. OTOH, with TBB 3.0 these directories appear at the last. I change the order of the directories to make it similar as in 2.2 but it didn't make any difference.
Continuing with your hint, I tried the following with puzzling behavior:
I tried compiling from source code, no luck. BTW, parallel_for with lamda works now with correct INSTALL_DIR. concurrent_bounded_queue and parallel_invoke fail. :(
Any more clues?
As of INCLUDE:
[bash]$ echo $INCLUDEThis does not seem to point to any TBB at all! But with the hint I checked the INSTALL_DIR, and it was wrong.
/opt/intel/Compiler/11.1/046/ipp/em64t/include:/opt/intel/Compiler/11.1/046/mkl/include[/bash]
[bash]$ echo $TBB30_INSTALL_DIRSo made the INSTALL_DIR to /opt/intel/tbb30_018oss. It still gave some errors.
/opt/intel/tbb30_018oss/bin/intel64/cc4.1.0_libc2.4_kernel2.6.16.21
$ echo $TBB_ARCH_PLATFORM
em64t/cc4.1.0_libc2.4_kernel2.6.16.21
[/bash]
[cpp]$ icc -I/opt/intel/tbb30_018oss/include -ltbb parallel_invoke.cppThe problem is with include, but I still can't figure out how to fix it! :(
/opt/intel/tbb30_018oss/include/tbb/parallel_invoke.h(48): error: no instance of function "FObject::operator()" matches the argument list and object (the object has cv-qualifiers that prevent a match)
object type is: const FObject
my_function();
detected during:
instantiation of "tbb::task *tbb::internal::function_invoker::execute() [with function=FObject]" at line 42
implicit generation of "tbb::internal::function_invoker::~function_invoker() [with function=FObject]" at line 42
instantiation of class "tbb::internal::function_invoker[with function=FObject]" at line 42
instantiation of "tbb::internal::function_invoker::function_invoker(const function &) [with function=FObject]" at line 132
instantiation of "void tbb::internal::parallel_invoke_helper::run_and_finish(const F0 &) [with F0=FObject]" at line 165
instantiation of "void tbb::parallel_invoke(const F0 &, const F1 &, tbb::task_group_context &) [with F0=FObject, F1=void ()]" at line 293
instantiation of "void tbb::parallel_invoke(const F0 &, const F1 &) [with F0=FObject, F1=void ()]" at line 29 of "parallel_invoke.cpp"
compilation aborted for parallel_invoke.cpp (code 2)
$ icc -I/opt/intel/tbb22_20090809oss/include/ -ltbb parallel_invoke.cpp
$ ./a.out
Hello World!
Yeah!
[/cpp]
Any more clues?
For parallel_invoke, the likely reason is a change we did in 2.2 Update 2:
- parallel_invoke and parallel_for_each now take function objects by const reference, not by value.
Due to that, you should declare the function call operator as const.
It doesn't seem to work
[cpp]#includeError:#include #include #define N 10 using namespace std; using namespace tbb; class FObject { public: void operator ()() const { cout << "Hello World!" << endl; } }; void Say() { cout << "Yeah!" << endl; } int main() { task_scheduler_init init(4); FObject f1; FObject f2; parallel_invoke( f1, f2); return 0; } [/cpp]
[bash]/tmp/ccOiTjCa.o: In function `tbb::internal::parallel_invoke_cleaner::~parallel_invoke_cleaner()': pi.cpp:(.text._ZN3tbb8internal23parallel_invoke_cleanerD1Ev[tbb::internal::parallel_invoke_cleaner::~parallel_invoke_cleaner()]+0x17): undefined reference to `tbb::interface5::internal::task_base::destroy(tbb::task&)' collect2: ld returned 1 exit status [/bash]
Thanks Alexey! That was the problem. I initially removed older tbb from intel 11.1, denied permission to look into TBB 2.2 directories. I verified that there are no libtbbs elsewhere, and complied. It worked! Then removed all tbbs but tbb30_018oss. Now everything works fine.
Thanks a lot again. :)
-S
-S
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
Topic Options
