TBB does compile within OpenCV under MinGW
Igor_S_2
been trying to compile TBB and here is what i get:
How to correct this?
Vladimir_P_1234567890
hello, what compiler version is used?
Igor_S_2
well, i am not sure, im not familiar with C++ compiling, the sequence was the following:
1. downloaded OpenCV
2. Downloaded CMake
3. Downloaded TBB
4. Run CMake
5.Choose MinGW compiler amount others, it was only one choice, as on picture:
6. Choose the OpenCV project, add WITH_TBB flag and BUILD_TBB flag
7. Generated and ran mingw32-make
i just need to run few of OpenCV applications with TBB support
could you run 'gcc -v' instead of 'mingw32-make' to get gcc version?
thanks
--Vladimir
Igor_S_2
4.7.2
