Understanding Internals of tbb::task
AJ13
I'm very confused as to what the reinterpret_casts within the allocation functions do. I don't see how you can get a pointer to the proxy from an instance of a tbb::task.
For example:
//! Returns proxy for overloaded new that allocates a child task of *this.
internal::allocate_child_proxy& allocate_child() {
return *reinterpret_cast<:ALLOCATE_CHILD_PROXY>(this);
AJ
RafSchietekat
Valued Contributor III
There is no actual proxy object: the pointer to "this" is just (temporarily) disguised as another type, to select a specific "operator new" overload (at compile time). I'm not sure what to think of it, though...
Alexey-Kukanov
Not only that, but also the pointer to the current task is passed to the real allocation function via such a masquerade, and used there. See the following methods that complement allocate_child():
[cpp]// in task.h
inline void *operator new( size_t bytes, const tbb::internal::allocate_child_proxy& p ) {
    return &p.allocate(bytes);
// in task.cpp
task& allocate_child_proxy::allocate( size_t size ) const {
    task& t = *((task*)this);
    __TBB_ASSERT( AssertOkay(t), NULL );
    GenericScheduler* v = static_cast(t.prefix().owner);
    return v->allocate_task( size, __TBB_ALLOC_TASK_ARGS(&t, t.prefix().depth+1, t.prefix().context) );
[/cpp]
Considered that there now exists five different proxy objects and correspondingly five overloaded operators new, some kind of pointer casting seems inevitable in order to pass task pointer to each one. The implementation could differ however; e.g. we could use five different unions instead of reinterpret_cast.
