Two after-build tests fail for the intel TBB source:
make rml (which by default also makes rml_test - which fails):
./test_rml_mixed.exe Assertion my_make_server_routine failed on line 86 of file ../../src/rml/client/rml_factory.h ../../build/Makefile.rml:150: recipe for target 'rml_test' failed make[1]: *** [rml_test] Aborted (core dumped) make[1]: Leaving directory '/path_to_src_dir/tbb43_VERSIONoss/build/linux_intel64_gcc_cc5.2.0_libc2.22_kernel4.2.0_debug' Makefile:50: recipe for target 'rml' failed make: *** [rml] Error 2
VERSION is confirmed to atleast be either 20150611 or 20150728.
Also the make-target `test` fails, at some point:
TBB Warning: RML might limit the number of workers to 7 while 15 is requested. Call stack info (6): ./test_tbb_fork.exe(_Z16print_call_stackv+0x44)[0x4045ba] ./test_tbb_fork.exe(_Z11ReportErrorPKciS0_S0_+0x1d)[0x4046a3] ./test_tbb_fork.exe(_Z8TestMainv+0x377)[0x404f45] ./test_tbb_fork.exe(main+0x2d)[0x404a1a] /usr/lib/libc.so.6(__libc_start_main+0xf0)[0x7f976d601610] ./test_tbb_fork.exe(_start+0x29)[0x4044a9] ../../src/test/test_tbb_fork.cpp:195, assertion 0: Hang after fork ../../build/Makefile.test:251: recipe for target 'test_tbb_plain' failed make[1]: *** [test_tbb_plain] Aborted (core dumped) make[1]: Leaving directory '/path_to_src_dir/tbb43_VERSIONoss/build/linux_intel64_gcc_cc5.2.0_libc2.22_kernel4.1.8_debug' Makefile:44: recipe for target 'test' failed make: [test] Error 2 (ignored)
The error in the `rml` target is that the assertion failed that 'factory' could not be opened - at least that's the comment above the critical line:
Same thing for the VERSION.
I could not check why both assertions fail (first: fail to open `factory`; second: thread hangs even after pkill and reaches code that shouldn't be reached). The issue not only exists on GCC5 but I also tested it on GCC4.9.
Any idea why the tests fail? Bug in the source or libraries?
Other links: https://bugs.archlinux.org/task/46160
- « Previous
- 1
- 2
- Next »
Hi
Archlinux update the TBB stack to 2021.4 in [testing] (include tbb4py)
update to build script for use system tbb instead bundled (downloaded from APT) get the same output (NULL platform behavior) when run clinfo
strace about missing IMRL library now is complete
openat(AT_FDCWD, "/usr/lib/libirml.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 P\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=51056, ...}, AT_EMPTY_PATH) = 0
close(3) = 0
munmap(0x7f3143bad000, 366360) = 0
mmap(NULL, 57592, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f3143bf8000
mprotect(0x7f3143bfd000, 28672, PROT_NONE) = 0
mmap(0x7f3143bfd000, 16384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x7f3143bfd000
mmap(0x7f3143c01000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x7f3143c01000
mmap(0x7f3143c04000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb000) = 0x7f3143c04000
mmap(0x7f3143c06000, 248, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f3143c06000
close(3)
so idk what happen here
greetings
Could you please let us know the command used to generate the log mentioned in the previous post?
Does this mean that your issue regarding the IMRL library was resolved?
Could you please do let us know the exact issue you are facing now?
Thanks & Regards,
Noorjahan.
Hi
simply `strace <app>`
`strace clinfo`
the missing library is now resolved, because Archlinux TBB package include it
https://archlinux.org/packages/testing/x86_64/tbb/files/
the same issue without the IMRL library (the root of the problem i think in the first time)
`clinfo` show:
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) No platform
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) No platform
clCreateContext(NULL, ...) [default] No platform
clCreateContext(NULL, ...) [other] Success [INTEL]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
Platform Name Intel(R) OpenCL
Device Name Intel(R) Xeon(R) CPU E5-2650 v4 @ 2.20GHz
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
Thanks for providing the details.
Could you please confirm whether the log provided in your previous reply is a complete log?
If not please provide us a complete log so that it would be helpful for us to get some more insights.
Please find the attached file for the output of "strace clinfo" command that we got on our end.
could you please let us know if you are looking for any specific information from the output of clinfo?
Thanks & Regards,
Noorjahan.
Hi
no, is not complete, is only the last part. the complete log is
only clinfo:
└───╼ clinfo
Number of platforms 2
Platform Vendor Intel(R) Corporation
Platform Version OpenCL 3.0 LINUX
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_spirv_linkonce_odr cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_khr_il_program cl_intel_unified_shared_memory_preview cl_intel_subgroups cl_intel_subgroups_char cl_intel_subgroups_short cl_intel_subgroups_long cl_intel_spirv_subgroups cl_intel_required_subgroup_size cl_intel_exec_by_local_thread cl_intel_vec_len_hint cl_intel_device_partition_by_names cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer
Platform Extensions with Version cl_khr_spirv_linkonce_odr 0x400000 (1.0.0)
cl_khr_icd 0x400000 (1.0.0)
cl_khr_global_int32_base_atomics 0x400000 (1.0.0)
cl_khr_global_int32_extended_atomics 0x400000 (1.0.0)
cl_khr_local_int32_base_atomics 0x400000 (1.0.0)
cl_khr_local_int32_extended_atomics 0x400000 (1.0.0)
cl_khr_int64_base_atomics 0x400000 (1.0.0)
cl_khr_int64_extended_atomics 0x400000 (1.0.0)
cl_khr_byte_addressable_store 0x400000 (1.0.0)
cl_khr_depth_images 0x400000 (1.0.0)
cl_khr_3d_image_writes 0x400000 (1.0.0)
cl_khr_il_program 0x400000 (1.0.0)
cl_intel_unified_shared_memory_preview 0x400000 (1.0.0)
cl_intel_subgroups 0x400000 (1.0.0)
cl_intel_subgroups_char 0x400000 (1.0.0)
cl_intel_subgroups_short 0x400000 (1.0.0)
cl_intel_subgroups_long 0x400000 (1.0.0)
cl_intel_spirv_subgroups 0x400000 (1.0.0)
cl_intel_required_subgroup_size 0x400000 (1.0.0)
cl_intel_exec_by_local_thread 0x400000 (1.0.0)
cl_intel_vec_len_hint 0x400000 (1.0.0)
cl_intel_device_partition_by_names 0x400000 (1.0.0)
cl_khr_spir 0x400000 (1.0.0)
cl_khr_fp64 0x400000 (1.0.0)
cl_khr_image2d_from_buffer 0x400000 (1.0.0)
Platform Numeric Version 0xc00000 (3.0.0)
Platform Extensions function suffix INTEL
Platform Host timer resolution 1ns
Platform Name NVIDIA CUDA
Platform Vendor NVIDIA Corporation
Platform Version OpenCL 3.0 CUDA 11.5.100
Platform Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info
Platform Extensions with Version cl_khr_global_int32_base_atomics 0x400000 (1.0.0)
cl_khr_gl_sharing 0x400000 (1.0.0)
cl_nv_compiler_options 0x400000 (1.0.0)
cl_nv_device_attribute_query 0x400000 (1.0.0)
cl_nv_pragma_unroll 0x400000 (1.0.0)
cl_nv_copy_opts 0x400000 (1.0.0)
cl_nv_create_buffer 0x400000 (1.0.0)
cl_khr_device_uuid 0x400000 (1.0.0)
cl_khr_pci_bus_info 0x400000 (1.0.0)
Platform Extensions function suffix NV
Platform Host timer resolution 0ns
Number of devices 1
Device Vendor Intel(R) Corporation
Device Vendor ID 0x8086
Device Version OpenCL 3.0 (Build 0)
Device Numeric Version 0xc00000 (3.0.0)
Driver Version 2021.12.9.0.24_005321
Device OpenCL C Version OpenCL C 3.0
Device OpenCL C all versions OpenCL C 0xc00000 (3.0.0)
OpenCL C 0x800000 (2.0.0)
OpenCL C 0x402000 (1.2.0)
OpenCL C 0x401000 (1.1.0)
OpenCL C 0x400000 (1.0.0)
Device OpenCL C features __opencl_c_3d_image_writes 0xc00000 (3.0.0)
__opencl_c_atomic_order_acq_rel 0xc00000 (3.0.0)
__opencl_c_atomic_order_seq_cst 0xc00000 (3.0.0)
__opencl_c_atomic_scope_device 0xc00000 (3.0.0)
__opencl_c_atomic_scope_all_devices 0xc00000 (3.0.0)
__opencl_c_device_enqueue 0xc00000 (3.0.0)
__opencl_c_generic_address_space 0xc00000 (3.0.0)
__opencl_c_fp64 0xc00000 (3.0.0)
__opencl_c_images 0xc00000 (3.0.0)
__opencl_c_int64 0xc00000 (3.0.0)
__opencl_c_pipes 0xc00000 (3.0.0)
__opencl_c_program_scope_global_variables 0xc00000 (3.0.0)
__opencl_c_read_write_images 0xc00000 (3.0.0)
__opencl_c_subgroups 0xc00000 (3.0.0)
__opencl_c_work_group_collective_functions 0xc00000 (3.0.0)
Latest comfornace test passed v2021-08-16-00
Device Type CPU
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Linker Available Yes
Max compute units 40
Max clock frequency 2200MHz
Device Partition (core)
Max number of sub-devices 40
Supported partition types by counts, equally, by names (Intel)
Supported affinity domains (n/a)
Max work item dimensions 3
Max work item sizes 8192x8192x8192
Max work group size 8192
Preferred work group size multiple (device) 128
Preferred work group size multiple (kernel) 128
Max sub-groups per work group 2048
Sub-group sizes (Intel) 4, 8, 16, 32, 64
Preferred / native vector sizes
char 1 / 32
short 1 / 16
int 1 / 8
long 1 / 4
half 0 / 0 (n/a)
float 1 / 8
double 1 / 4 (cl_khr_fp64)
Half-precision Floating-point support (n/a)
Single-precision Floating-point support (core)
Denormals Yes
Infinity and NANs Yes
Round to nearest Yes
Round to zero No
Round to infinity No
IEEE754-2008 fused multiply-add No
Support is emulated in software No
Correctly-rounded divide and sqrt operations No
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Address bits 64, Little-Endian
Global memory size 135202459648 (125.9GiB)
Error Correction support No
Max memory allocation 33800614912 (31.48GiB)
Unified memory for Host and Device Yes
Shared Virtual Memory (SVM) capabilities (core)
Coarse-grained buffer sharing Yes
Fine-grained buffer sharing Yes
Fine-grained system sharing Yes
Atomics Yes
Minimum alignment for any data type 128 bytes
Alignment of base address 1024 bits (128 bytes)
Preferred alignment for atomics
SVM 64 bytes
Global 64 bytes
Local 0 bytes
Atomic memory capabilities relaxed, acquire/release, sequentially-consistent, work-group scope, device scope, all-devices scope
Atomic fence capabilities relaxed, acquire/release, sequentially-consistent, work-item scope, work-group scope, device scope, all-devices scope
Max size for global variable 65536 (64KiB)
Preferred total size of global vars 65536 (64KiB)
Global Memory cache type Read/Write
Global Memory cache size 262144 (256KiB)
Global Memory cache line size 64 bytes
Image support Yes
Max number of samplers per kernel 480
Max size for 1D images from buffer 2112538432 pixels
Max 1D or 2D image array size 2048 images
Base address alignment for 2D image buffers 64 bytes
Pitch alignment for 2D image buffers 64 pixels
Max 2D image size 16384x16384 pixels
Max 3D image size 2048x2048x2048 pixels
Max number of read image args 480
Max number of write image args 480
Max number of read/write image args 480
Pipe support Yes
Max number of pipe args 16
Max active pipe reservations 6553
Max pipe packet size 1024
Local memory type Global
Local memory size 32768 (32KiB)
Max number of constant args 480
Max constant buffer size 131072 (128KiB)
Generic address space support Yes
Max size of kernel argument 3840 (3.75KiB)
Queue properties (on host)
Out-of-order execution Yes
Profiling Yes
Local thread execution (Intel) Yes
Device enqueue capabilities supported, replaceable default queue
Queue properties (on device)
Profiling Yes
Preferred size 4294967295 (4GiB)
Max size 4294967295 (4GiB)
Max queues on device 4294967295
Max events on device 4294967295
Prefer user sync for interop No
Profiling timer resolution 1ns
Execution capabilities
Run OpenCL kernels Yes
Run native kernels Yes
Non-uniform work-groups Yes
Work-group collective functions Yes
Sub-group independent forward progress No
IL version SPIR-V_1.0
ILs with version SPIR-V 0x400000 (1.0.0)
SPIR versions 1.2
printf() buffer size 1048576 (1024KiB)
Built-in kernels (n/a)
Built-in kernels with version (n/a)
Device Extensions cl_khr_spirv_linkonce_odr cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_byte_addressable_store cl_khr_depth_images cl_khr_3d_image_writes cl_khr_il_program cl_intel_unified_shared_memory_preview cl_intel_subgroups cl_intel_subgroups_char cl_intel_subgroups_short cl_intel_subgroups_long cl_intel_spirv_subgroups cl_intel_required_subgroup_size cl_intel_exec_by_local_thread cl_intel_vec_len_hint cl_intel_device_partition_by_names cl_khr_spir cl_khr_fp64 cl_khr_image2d_from_buffer
Device Extensions with Version cl_khr_spirv_linkonce_odr 0x400000 (1.0.0)
Number of devices 1
Device Name NVIDIA GeForce GTX 1070 Ti
Device Vendor NVIDIA Corporation
Device Vendor ID 0x10de
Device Version OpenCL 3.0 CUDA
Device UUID 51ab6f21-790f-c44c-43f0-0c089b0e253b
Driver UUID 51ab6f21-790f-c44c-43f0-0c089b0e253b
Valid Device LUID No
Device LUID 6d69-637300000000
Device Node Mask 0
Driver Version 495.44
Device OpenCL C Version OpenCL C 1.2
Device OpenCL C all versions OpenCL C 0x400000 (1.0.0)
Device OpenCL C features __opencl_c_fp64 0xc00000 (3.0.0)
Latest comfornace test passed v2021-02-01-00
Device Type GPU
Device Topology (NV) PCI-E, 0000:03:00.0
Max compute units 19
Max clock frequency 1683MHz
Compute Capability (NV) 6.1
Max number of sub-devices 1
Supported partition types None
Max work item sizes 1024x1024x64
Max work group size 1024
Preferred work group size multiple (device) 32
Preferred work group size multiple (kernel) 32
Warp size (NV) 32
Max sub-groups per work group 0
char 1 / 1
short 1 / 1
int 1 / 1
long 1 / 1
half 0 / 0 (n/a)
float 1 / 1
double 1 / 1 (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Correctly-rounded divide and sqrt operations Yes
Denormals Yes
Round to zero Yes
Global memory size 8478654464 (7.896GiB)
Max memory allocation 2119663616 (1.974GiB)
Unified memory for Host and Device No
Integrated memory (NV) No
Fine-grained buffer sharing No
Fine-grained system sharing No
Atomics No
Alignment of base address 4096 bits (512 bytes)
SVM 0 bytes
Global 0 bytes
Local 0 bytes
Atomic memory capabilities relaxed, work-group scope
Atomic fence capabilities relaxed, acquire/release, work-group scope
Max size for global variable 0
Preferred total size of global vars 0
Global Memory cache size 933888 (912KiB)
Global Memory cache line size 128 bytes
Image support Yes
Max number of samplers per kernel 32
Max size for 1D images from buffer 268435456 pixels
Max 2D image size 16384x32768 pixels
Max 3D image size 16384x16384x16384 pixels
Max number of read image args 256
Max number of write image args 16
Max number of read/write image args 0
Pipe support No
Max number of pipe args 0
Max active pipe reservations 0
Max pipe packet size 0
Local memory type Local
Local memory size 49152 (48KiB)
Registers per block (NV) 65536
Max number of constant args 9
Max constant buffer size 65536 (64KiB)
Generic address space support No
Max size of kernel argument 4352 (4.25KiB)
Profiling Yes
Device enqueue capabilities (n/a)
Out-of-order execution No
Profiling No
Preferred size 0
Max size 0
Max queues on device 0
Max events on device 0
Profiling timer resolution 1000ns
Run native kernels No
Non-uniform work-groups No
Work-group collective functions No
Kernel execution timeout (NV) No
Concurrent copy and kernel execution (NV) Yes
Number of async copy engines 2
IL version (n/a)
ILs with version <printDeviceInfo:186: get CL_DEVICE_ILS_WITH_VERSION : error -30>
Built-in kernels with version <printDeviceInfo:190: get CL_DEVICE_BUILT_IN_KERNELS_WITH_VERSION : error -30>
Device Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info
Device Extensions with Version cl_khr_global_int32_base_atomics 0x400000 (1.0.0)
strace clinfo (see the attached file esee.log)
viewing you log, have the same output like me (the last part, talking about NULL platform behavior)
so maybe is the output in a normal execution
greetings
Could you please confirm whether your issue is resolved? If yes, can we go ahead and close this thread?
Thanks & Regards,
Noorjahan.
if you can confirm that message os correct behavoir, then yes
greetings
We are working on your issue. We will get back to you soon.
Thanks & Regards,
Noorjahan.
>> oneAPI suit also complains about libirml.so library
libirml.so is a special purpose library that is used only with tbb4py package. Regular oneTBB and Intel OpenCL runtimes do not require this library. Pay attention that strace does not show errors but only logs return statuses of particular system function. I.e. the fact that libirml.so is not found is not a error, it is expected behavior when oneTBB runtime uses dlopen to query if libirml.so present or not.
I think this issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Thanks!
![](/skins/images/8B5EA638CA3587CA763EE9EF53643DD4/responsive_peak/images/icon_anonymous_message.png)
- « Previous
- 1
- 2
- Next »
