Hi there,
The snippet below will crash after a while with an access violation somewhere below tbb_debug.dll!concurrent_queue_base_v3::internal_push() when running 1 tbb thread for consume() and 10 for produce(). This is reproducible on my Vista 64 Box (snippet is compiled to 32 bits/debug). I am using Studio 2008 SP1. Any ideas?
struct QueuedCall
void unblock() { myQueue.push(1); }
void block() {
int dummy;
myQueue.pop(dummy);
tbb::concurrent_bounded_queue myQueue;
tbb::concurrent_queue myPendingCalls;
void consume() {
do {
QueuedCall *call;
if (myPendingCalls.try_pop(call))
call->unblock();
} while (true);
void produce() {
for (;;) {
QueuedCall *c = new QueuedCall();
myPendingCalls.push(c);
c->block();
delete c;
That's not surprising since you delete an item straight after enqueue, so the queue basically transfers dangling pointers between threads.
Then perhaps the problem is that an item (hence the myQueue queue) is deleted between an item become available for consuming and return from push(). You must guarantee the myQueue's life-time till return from push().
Consider schematic push() implementation:
... push(...)
make an item available for consuming
// at this point consumer pops the item and deletes the queue (this)
some more operations with this' members, which result in paging fault because 'this' is already deleted
Mike
Why you made such conclusion? You can indeed pass pointers and delete them on consumer side.
However, you must not delete the queue itself while there are threads still executing it's methods. That's the basic safety rule equally applicable to all types out there.
Mike
I still can't make up my mind on this. Whether queues must support such usage patterns or not. But I am inclining to the answer No, they do not have to.
There is a lot of "strange" usage patterns a user can think up. For example consider:
queue* q = new queue;
q->enqueue(1);
// thread 1
if (false == q->dequeue())
delete q;
// thread 2
delete q;
So enqueue() must be strictly lineariazable too to support such pattern.
Then, it seems that for each "strange" use pattern there is a "normal" implementation that achieves the same.
Then, support for such "strange" use patterns can penalize performance for "normal" use patterns.
So I guess it's Ok to just prohibit such "strange" use patterns.
[cpp]struct tcp_connection { queue_t q; ... }; void connection_thread(tcp_connection* c) { for (;;) { msg_t* m = c->dequeue(); if (m->type == MSG_DISCONNECT) { delete c; return; } process(m); } } void io_dispatch_thread() { for (;;) { select(...); for_each(SOCKET s in read_set) { recv(s, buf, size); tcp_connection* c = find_connection(s); c->enqueue(msg_t(MSG_PACKET, data, size)); } for_each(SOCKET s in exception_set) { tcp_connection* c = find_connection(s); c->enqueue(msg_t(MSG_DISCONNECT)); } } } [/cpp]
Are not smart pointers the usual solution for this type of problems?
What type of problem?
The problem is that while one uses mutex-based queue he has no problems, and once he switches to TBB he starts getting chaotic memory corruptions and crashes.
Mike
Please, elaborate. I do not see why my example won't work with a mutex-based queue.
Maybe I didn't see the correct problem then; can you explain how your example could fail?
Mike
but not yet return from enqueue()
Connection thread receives the message:
msg_t*m=c->dequeue();
if(m->type==MSG_DISCONNECT)
and deletes the queue:
deletec;
Now dispatch thread crashes in enqueue().
It shouldn't, but that ignores the point that many people, especially to those with experience with a mutex based queue, will probably find this behavior initially surprising and not initially intuitive.
Mike
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
