2455 Discussions
class-memaccess warning when compiling with gcc-10.2
watch_the_crab
Hi, got following warning when compiling with GCC-10.2. TBB 2020.2
Any ideas? Thanks!
/opt/intel/tbb/include/tbb/concurrent_hash_map.h: In constructor ‘tbb::interface5::internal::hash_map_base::hash_map_base()’:
/opt/intel/tbb/include/tbb/concurrent_hash_map.h:131:76: error: ‘void* memset(void*, int, size_t)’ clearing an object of type ‘struct tbb::interface5::internal::hash_map_base::bucket’ with no trivial copy-assignment; use value-initialization instead [-Werror=class-memaccess]
  131 |             std::memset(my_embedded_segment, 0, sizeof(my_embedded_segment));
/opt/intel/tbb/include/tbb/concurrent_hash_map.h:93:16: note: ‘struct tbb::interface5::internal::hash_map_base::bucket’ declared here
   93 |         struct bucket : tbb::internal::no_copy {
Pavel_K_Intel1
Hello, thanks for the report. This error will be fixed in future updates.
GouthamK_Intel
Can you install the latest version of Intel OneAPI i.e 2021.2 and check whether your issue persists? If yes, Could you please provide a sample reproducer code?
Thanks & Regards,
Goutham
GouthamK_Intel
Reminder: Could you please install the latest version of Intel OneAPI i.e 2021.2 and check whether your issue persists? If yes, Could you please provide a sample reproducer code?
Thanks & Regards,
Goutham
GouthamK_Intel
As we have not heard back from you, we are considering that your issue has been resolved and we have answered all your queries. So we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
Have a Good day!
Thanks & Regards
Goutham
