tbb::task_scheduler_init class (newbie)
yesilgulalp
In the past, there was a class named "task_scheduler_init" in the "tbb" library, but I think that class does not exist anymore. For example, instead of the "tbb :: task_scheduler_init :: default_num_threads ()" function, there could be an approach like this link -> https://github.com/oneapi-src/oneTBB/issues/248
My question is how can I determine how many threads to use for execution. Specifically "tbb :: task_scheduler_init init {number};" What can I use instead?
James_T_Intel
You will need to use task_arena and control the concurrency to achieve this effect. When you create a task_arena, you can specify the maximum concurrency, which will set how many threads are used. Please see https://software.intel.com/content/www/us/en/develop/documentation/tbb-documentation/top/intel-threading-building-blocks-developer-reference/task-scheduler/taskarena-class.html for details.
AbhishekD_Intel
As this issue is more related to TBB, we are moving this issue to the oneAPI TBB forum.
Warm Regards,
Abhishek
James_T_Intel
James_T_Intel
This issue has been resolved and we will no longer monitor this thread. If you require additional assistance from Intel, please start a new thread.Any further interaction in this thread will be considered community only.
