2485 Discussions
unsafe_bucket_size in concurrent_unordered_base is not const?
nash635
I'm reading the source code of the concurrent_unordered_map, and found it's interface  unsafe_bucket_size is designed with non-const function,
so just curious is this by design? i guess if some body invoke this method in a const method, the compiler will not allow that.
https://github.com/intel/tbb/blob/tbb_2020/include/tbb/internal/_concurrent_unordered_impl.h
// Bucket interface - for debugging
    size_type unsafe_bucket_count() const {
        return my_number_of_buckets;
    size_type unsafe_max_bucket_count() const {
        return segment_size(pointers_per_table-1);
    size_type unsafe_bucket_size(size_type bucket) { // ====> non const?
        size_type item_count = 0;
        if (is_initialized(bucket)) {
            raw_iterator it = get_bucket(bucket);
            ++it;
            for (; it != my_solist.raw_end() && !it.get_node_ptr()->is_dummy(); ++it)
                ++item_count;
        return item_count;
    size_type unsafe_bucket(const key_type& key) const {
        sokey_t order_key = (sokey_t) my_hash_compare(key);
        size_type bucket = order_key % my_number_of_buckets;
        return bucket;
Alina_S_Intel
Sorry for the delayed response.
unsafe_bucket_size is const in oneTBB so the issue is fixed in the latest release:
https://github.com/oneapi-src/oneTBB/blob/9e15720bc7744f85dff611d34d65e9099e077da4/include/oneapi/tbb/detail/_concurrent_unordered_base.h
Alina_S_Intel
We will no longer respond to this thread.
If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
