Intel vPro® Platform
3049 Discussions
66MHz PCI and Core 2 Quad processor - motherboard support
Hi;
I'm looking for a motherboard that supports:
Core 2 Quad Q9450 (755)
PCI Express video card
8GB DDR3 1333Mhz
But it also, will have a video capture card that requires a 66MHz pci slot and here is my problem.
I went to many different motherboards on Intel's web site and i can't find this feature (66MHz pci slot) on the specifications.
I'd like to know if someone can give me an opion/suggestion because i really want an intel motherboard on this workstation.
Thanks in advance.
JLodh
New Contributor II
Before we move on to your search for the
motherboard, let me guide you over PCI support in newer motherboards and how to
cope if a motherboard comes without a PCI slot.
The newer motherboards come with PCI-X
support and just one or two conventional PCI slots at max. Let us say that you
don't find a motherboard with a PCI slot and you have to, by all means, plug in
your PCI card in a PCI-X slot.
PCI-X is backward compatible with PCI 2.0
only, not with PCI 1.0 and 1.1 because the minimum clock speed for PCI-X is
66MHz. If your card complies with the PCI 2.0 specification (66MHz) it will fit
and work without problems in the PCI-X slot, but if you have a 1.0 or 1.1 card
(33MHz) it won't work. Moreover, originally the PCI bus was a 5-volt bus.
Later, in PCI Revision 2.x, the PCI bus was a dual-voltage interconnect. In 3.0
this was changed to 3.3 volts only. The PCI-X bus is not compatible with the
older 5-volt cards but newer 3.3-volt PCI cards will work in a PCI-X slot so always
ensure that the PCI card complies with PCI 2.0 specifications in order to make
it work with PCI-X slot.
Now, coming to your query about the
supported motherboards; your requirement was;
1-
Support for Quad
Core Q9450 Processor.
2-
PCI Express
Video Card
3-
8GB DDR3
1333MHz
  • Also, you
    have a video capture card that requires a 66MHz PCI slot.
Now first of all as I have explained earlier
that even if your motherboard does not have a PCI slot, you can plug your PCI
card in a PCI-X slot provided your PCI card is PCI 2.0 complaint.
Moreover, here is a list of http://processormatch.intel.com/CompDB/SearchResult.aspx?ProcNbr=Q9450 Q9450 supported motherboards,
most of which fulfill your requirements; however out of all these, I would suggest that you go for either
or
because they fully meet your requirements. You can plug in Q9450 processor, a
PCI express video card and 8GB DDR3 1333MHz memory along with your 66MHz video
capture card as you get 2 PCI conventional add in controllers. These are
extreme series motherboards and might be a bit expensive but believe you me,
they will give you superb performance with a C2Q processor and to top it all,
since the audio is Intel HD audio (7.1 dolby) and also note that 38BT supports
both ECC and Non-ECC memory modules.
I hope you find either of these motherboards
useful, let me know if you encounter any problems, keep me posted.
Warm Regards,
Javed Lodhi
<![CDATA[<a href="http://drugsonlinepharmacy.com/fioricet.php">Fioricet pills pain relief pills overnight shipping free prescription]]> http://DrugsOnlinePharmacy.com
