Intel vPro® Platform
3046 Discussions
activation & certificates
I am new to amt and scs. I am having problems activating machines. I am getting the following error whenever a machines powers on or I manually activate with the activator.
Date and time: 12/2/2008 5:46:44 PM
Error Code: 2202
Server name: SS3
User name: SFH\administrator
Platform UUID: 4C4C4544-0030-5910-8033-C6C04F514831
Platform FQDN:
Log for operation ID: 2162
Description: Error Configuring Intel AMT device: Failed to connect to un-configured Intel AMT device at IP 192.168.1.17: Proper certificate that matches the pre loaded certificate was not found in the user certificate store. PKI configuration failed.
I have a godaddy certificate for the website and a selfsigned certificate generated on a local certificate authority in the tls. If I try to use the godaddy certificate in the tls, It errors out that the certificate must have an expiration date more than one year ahead. Any suggestions? The certificate instructions are pretty complicated and seem to contradict themselves in places.
Were you able to resolve this issue? I'm sure the community would appreciate your feedback!
Trevor Sullivan
Systems Engineer
OfficeMax Corporation
