I have an old Fujitsu Siemens Esprimo P5925, Mobo D-2584-A12 Gs3 version with Q9650, 8 GB ddr2, , GPU Quadro FX 4600. Win 11, BIOS IS updated in 2021.
Now I have a problem that an error comes on screen "MEBx error: FW init complete not set" press any key to continue. I tried lots of time no windows installation . No BIOS were updated because of above error PC com on blue error screen windows repair but not a single functional keys working I have installation media disk but not to repair windows. I try to add an other HDD, M. 2 BUT no media disk or flash drive working strating but after 3 to 5 minutes blue screen comes again & again.
So any one have solution please guide me.
Hello Papobhai,
Greetings!
The Management Engine BIOS Extension (MEBx) is an extension to the BIOS and is controlled by the OEM/BIOS provider. Different vendors may offer varying methods to access the MEBx settings. While the typical method involves pressing "Ctrl-P" during boot, some vendors might use different keys or methods.
Here are a few suggestions you can try:
- Check BIOS Settings: Look for any BIOS settings that might enable the display of the "Ctrl-P" prompt during boot.
 - Try Alternative Boot Hotkeys: Experiment with other boot hotkeys provided by your OEM to see if they give you access to the MEBx.
If these methods don't work, I recommend contacting your OEM or BIOS vendor directly. They will be able to provide guidance on how your specific BIOS version offers access to the MEBx.
Please let me know if you need further assistance.
Vijay N.
Hello Papobhai,
Greetings!
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know.
Vijay N.
Hello Papobhai,
Greetings!
If further assistance is necessary, do not hesitate to reply.
Vijay N.
No nothing is working i already updated the BIOs before getting you help.
No any support for a 14 years old system , i already join just like intel community to FTS community but until not helpful to me.
now i have checked my hardware one ram stick is not working properly, removed from mobo than my PC working with below conditions:
1. system when shutdown cpu power always on until i physically switched off from main power source.
2. Some times when system on Cpu fan running high & make sound but PC not starting.
3. But until i use it problematic PC MEBx erro.
4. i typed this message from this PC now
Thanks for guidance but no any result yet.
