Intel vPro® Platform
3025 Discussions
AMT SDK RemoteControlTyped/Untyped.exe aborts during enumerate
Hi experts,
I have two laptops - one is a vPro enabled and another is a non-vPro laptop. I successfully built the RemoteControlTyped and RemoteControlUntyped.exe applications that are part of the SDK on my non-vPro laptop. Here is what I tried:
remotecontroltyped.exe -c -verbose -host -user admin -pass
What I see is a "Debug Assertion Failed"
Expression: map/set iterator not dereferenceble.
So I tried to pass the arguments into the IDE(visual studio 2008) and run in debug mode where I set breakpoints. I see that it hits this error when attempting to perform an Enumerate on Cim_RegisteredProfile.
Since I am fairly new to this stuff I am looking for help on what could be causing and what I can do to get past this. Is there some other application I need to run before running the remote control? I did not quite figure out what it is trying to enumerate.
Appreciate your help.
Sudarsan VS.
hello
let me ask you some questions about your system to see how can we help you:
  1. Did you provisioned/configured your AMT?
  2. Which AMT version do you have?
  3. Are you working over a secure tunnel?
  4. Does the following URL (anable to contact AMT via browser also named as "Web UI") works for you: http://yourAMTadress:16992/index.htm http://yourAMTadress:16992/index.htm
After having some answer i am sure we can progress prrety fast.
Nati
