We have 80 Intel PC's with the DQ35JO motherboard. These models has the Intel AMT version 3.2.x. We try to activate the AMT using the SCS 6.XX with the CLI Activator. The results are as follows:
Activator.exe /verbose /keepLogFile /status
CLI: Exit with code 0 (Request finished successfully).
Activator.exe /verbose /keepLogFile /destination serverXX /userName "userXX" /password "passXX" /psk /newMePassword "passXXX"
SCS: Succeeded Import of PSK
Activator.exe /verbose /keepLogFile /destination serverXX /userName "userXX" /password "passXX" /sendHello
CLI: Finished: SendHelloMessage
SCS: Succeeded Process Hello Message, SCS Code: 6214,
Activator.exe /verbose /keepLogFile /destination serverXX /userName "userXX" /password "passXX" /profileid 1 /ADOU "OU=OrdenadoresAMT,DC=xxxx,DC=xxx"
CLI: After various checks
Finished: SendConfigurationRequest
Exit with code 15 (Intel(R) AMT system is not configured yet).
SCS:
Various Failed Configurations: SCS Code: 2002 Failed while calling Soap call GetCoreVersion. AMT Connection Error 4022: An HTTP error occurred, error in discover 4022
Finally: Failed Configuration: SCS Code: 5014SCS Code: 5015
We change the profile with different settings but no advance
The desktops works Ok configuring it whit the
Some ideas?
Thanks in advance
a couple of things to check on, what is the full build of the AMT Fw 3.2.??? - are you trying to provision with a certificate? if so which one? tell me aobut your domain and use of subnets.
check the Intel web site for the latest bios F/W build and drivers SOL/LMS, its 3.2.40.1057 FW kit and will be located on Intel Download Center under the "Discontinued Products" section for Desktop Boards/Intel 3-series chipsets. there werre multiple repairs for multi domain and subnet provisioning along with soem security updates...let me know if you ahve any othere issues
