Intel vPro® Platform
3046 Discussions
Best management software for Vpro
I have @ 1000 VPro enabled Pc's in @50 location connected through VPN network. I I would like to know,which is best software availble?
I know, there are four major vendor, SCCM, Landesk, Alitiris and HP. I need to know, what is most widly used software with all features?
I would like to know, Which method should I use for TLS? PPS or PKI? PKI is very complicated and requeires cerificate server. I am not sure, how enterprise CA integrate in head office /domain and subdomain environment. What will happen if Microsoft CA is unavailble for any reason, Am I going to loose full control on AMT device? Do I need backup CA at seperate site? Does it requires microsoft enterprise CA at central location or each branch location as well?
Soni
MICHELE_G_Intel
Hi Soni,
We have an interactive software catalog that can help you choose a software vendor based on your needs. Please visit our http://www.intel.com/itcenter/tool/vpro/index.htm Intel vPro Activation web site and click on Step 3: Find the Right Software. Once you choose your software, you can proceed to Step 4: Create a Customized Activation Recommendation. That will give you some ideas based on your network setup.
Michele Gartner
Community Manager
Intel vPro Expert Center
