Intel vPro® Platform
3077 Discussions
DP55WB Mother Board not installing Windows XP Pro
Just built a new computer featuring this DP55WD Mother Board and a quad core intell processor. For some reason when I try and boot with my Windows XP professional disk I get the blue screen of death. It never gets to the place where I can even format the hard drive. I have checked the bios settings and read the manual. The manual states that Under Advanced settings I can set the SATA drive. It is not as stated in the manual but the SATA drive is set to IDE.
Nothing else makes sense unless Windows XP Pro is not compatable with this chip set???
Can anyone help me with this delema???
try installing vista or 7
also try to check the memory and hdd for errors
try to change sata drive from ide to sata
do you hae enough cooling
or your cd is corrupt
Check if you need to load the CD driver and try XP with SP2 on the CD.
